5sp swap with XT6 clutch
I've got an 85 BRAT with an 85 5sp d/r in it with a brand spanking new XT6
clutch attached to an EA82 flywheel resurfaced to XT6 specs.
It won't let go...
I've been readjusting the cable almost to the point I'm afraid of getting the
throwout bearing stuck on the end of the shaft it slides on.
I've had to fix that problem once before :(
So, I've got everything set properly, what am I missing?
I'm currently investigating the cable, but I've practically ran out of threading on
the top side of the cable, and it still won"t let go.
Anybody run into this issue?
Twitch
hi ,
there are a couple of different forks that were used in ea-81 and ea-82, which one do you have installed? the fsm says some were 2:1 and some were 3:1 ratio of leverage. if you are sure the disc is turned the right way ,the fork might be the issue. also do you know what was the spec they used on the ea82 flywheel??
Edited by ruparts
Well, it looks like I need the longer throw fork.
Gotta pull it apart. Again.
And get the fork from the J/Y, unless somebody wants to donate one :-\
Woo... :(
Twitch
PS: Aside from an XT6, what fork should be the longer throw?
A Turbo?
Edited by Twitch de la Brat
Forgot Details
