Bluestone Posted February 5, 2011 Share Posted February 5, 2011 After starting up with a cold engine, the idling speed on my 2000 Legacy wagon will surge to 3k RPM. It'll drop back down if I goose the gas pedal. Any adjustments that I can easily make at my end to eliminate the too fast cold idle? There's no snow and ice here, just temps ranging from 35° F - 65° F. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 5, 2011 Share Posted February 5, 2011 Sounds like a dirty idle air controller I had the same issue here until I cleaned mine.. If you do go that way make sure you have a new gasket on hand. Quote Link to comment Share on other sites More sharing options...
Bluestone Posted February 6, 2011 Author Share Posted February 6, 2011 Sounds like a dirty idle air controller I had the same issue here until I cleaned mine.. If you do go that way make sure you have a new gasket on hand. Do you or anyone have a photo or drawing showing where the idle air controller is located? Quote Link to comment Share on other sites More sharing options...
bstone Posted February 6, 2011 Share Posted February 6, 2011 Just follow the small air hose coming from the intake ducting. It goes right to the IAC. Quote Link to comment Share on other sites More sharing options...
