True2Blue Posted February 6, 2011 Share Posted February 6, 2011 i have a 86 d/r and need to take notes on the clutch sizes the 7 7/8 disk is for FWD only correct? the 8 7/8 disk is for the 4wd d/r ?? its for a 98 legacy with the 86 d/r 21 or 24 spline? what other options do i have Link to comment Share on other sites More sharing options...
True2Blue Posted February 6, 2011 Author Share Posted February 6, 2011 i have a 8 7/8 24 spline on order i wanna get it done asap Link to comment Share on other sites More sharing options...
81EA81 Posted February 6, 2011 Share Posted February 6, 2011 When I went to napa to get a new clutch for my 86 Brat(EA81) they gave me a clutch kit for an 86 GL wagon(EA82) which is 24 spline.The pressure plate seemed to fit on the flywheel fine, same with the pilot bearing, but the friction disk was 3 splines to big for the transmission shaft. The 24 spline 8 7/8 should fit fine. I dont know about the 7 7/8 disk for FWD, mines 4wd 8 7/8 Link to comment Share on other sites More sharing options...
True2Blue Posted February 6, 2011 Author Share Posted February 6, 2011 When I went to napa to get a new clutch for my 86 Brat(EA81) they gave me a clutch kit for an 86 GL wagon(EA82) which is 24 spline.The pressure plate seemed to fit on the flywheel fine, same with the pilot bearing, but the friction disk was 3 splines to big for the transmission shaft. The 24 spline 8 7/8 should fit fine. I dont know about the 7 7/8 disk for FWD, mines 4wd 8 7/8 i read ofter hours of searching and it ways the 21 spline is for the hatchback and brat some sites seem to mix the diameter and splines up which made it hard on me Link to comment Share on other sites More sharing options...
GLCraig Posted February 6, 2011 Share Posted February 6, 2011 IIRC 21 spline is for EA81 2wd/4wd and EA82 N/A 2wd. 24 spline is for EA82 4wd and 2wd turbo. Link to comment Share on other sites More sharing options...
T'subaru Posted February 7, 2011 Share Posted February 7, 2011 Ive found rockauto.com and also this ebay seller a good source of clutch dimension and spline count info. http://stores.ebay.com/gripforce-clutches_Subaru_W0QQ_fsubZ18QQ_sidZ98015562QQ_trksidZp4634Q2ec0Q2em322 Link to comment Share on other sites More sharing options...
