Starting Problems..
I have an 87 Rx with an ea82t, so I tried to start it one morning and it would not crank over. Figured it was the starter because I knew it was bad(had to hit it every once and a while for it to turn on) well I replaced that , also replaced the battery because it wasn't showing any volts when I first put the key in. So with the new starter and battery in it, I put the key in and it showed volts, soon as I turned it something clicked and then it didn't show any volts again... now I'm just lost...Any ideas?
  • 1 month later...
I was told it was a bad terminal connection
Yup! I just took a look at my battery connections and found they were very loose and rusy. Spent a minute with a wire wheel and a wrench and it solvrd all my issues.
