amr9000 Posted February 18, 2011 Share Posted February 18, 2011 just tore apart the inside of my 96 impreza outback, took almost every immediate thing off of the interior.. cleaning anndd fixing this and that... I'm a bit of a neat freak, Anyway I've got a bad transmission (though well taken care of, gone at past 200,000) going to be replacing that soon as I can, and the engine will probably be next but we'll try and keep that clean... so any wise words are Very welcome, I'd like to try and keep this thing as clean and smooth as I can.... Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted February 21, 2011 Share Posted February 21, 2011 Welcome! Sounds like you've got an auto, correct? You can swap in a manual with a little wiring and some pedal swapping. Or a replacement auto can be put directly in, no rewiring required. Your engine is non-interference, so if it busts a timing belt or a pulley, you're good Also, unless you know it has been done recently, I would recommend changing the timing pulleys and the belt and possibly the water pump. That will ensure another 60k miles of no worry driving. At least for the engine timing :-p Twitch Link to comment Share on other sites More sharing options...
amr9000 Posted February 21, 2011 Author Share Posted February 21, 2011 noo it's a five speed, that's interesting to know though.. knew about the non-interferance, loving that the timing belt has been done recently, not sure about the water pump... how much they usually run? thankya for thaat info, more's welcome Link to comment Share on other sites More sharing options...
xbeerd Posted February 21, 2011 Share Posted February 21, 2011 Alot of times the timing belt and waterpumps are done at the same time since its the same process to go thru up to changing the pump and or belt. So you might have a newer water pump too. at 200k i would hope they'd do that anyways. whats the problem with the trans? i dont hear too often a manual trans goin bad on these. I just put a manual trans in my car last year and it had 212k on it! LOL. Link to comment Share on other sites More sharing options...
chef_tim Posted February 21, 2011 Share Posted February 21, 2011 I'm wondering if the tranny problem might not be a clutch problem?? Welcome to the USMB, if you are a neat freak I suggest you stay away from any thread with the word mud in it, could be hard on you... Link to comment Share on other sites More sharing options...
amr9000 Posted February 22, 2011 Author Share Posted February 22, 2011 hhmm well the last guy to own it just kinda.. drove it... didn't take care of it, he said third gear just kind of stopped working.. not exactly willing to risk trying to rebuild it, I'm kinda on a budget... Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted February 22, 2011 Share Posted February 22, 2011 Hey, don't worry, we're all on budgets around here. Can you describe what happens if you put it into 3rd while the engine is running, and then let out the clutch? Twitch PS:If you need any body replacement panels, pretty much any Impreza from 93-02 or 03 will match up without issue. Link to comment Share on other sites More sharing options...
amr9000 Posted February 23, 2011 Author Share Posted February 23, 2011 aren't we all these days? no, the guy I bought it from just said it didn't work and he... fricken.. gave it to me with the front right half axle.. Off the car.. so I need to put it back together to even know how it drives... I do know while the engine is running, when you put the clutch in all the way it makes a kind of.. brushing? sound... and that body hint is Awesome I like that, except you Cannot find subarus in junk yards.. >.< course that's probly a good sign.. considering you could probly Build an american car out of a junk yard.. Link to comment Share on other sites More sharing options...
Dj7291993 Posted February 23, 2011 Share Posted February 23, 2011 Must just be your junkyard. The local pull-and-pay usually has at least 8-10 gl's, and around 6 legacy's. But I think they are usually wrecked. Anyway, welcome, and best of luck to you. The guys around here are VERY helpful. Link to comment Share on other sites More sharing options...
amr9000 Posted February 24, 2011 Author Share Posted February 24, 2011 went to three :\ I've noticed, I'm looking forward to it Link to comment Share on other sites More sharing options...
