awakethroughmot Posted February 19, 2011 Share Posted February 19, 2011 (edited) last week someone tried and failed stealing my 88 gl wagon from outside my house. they basically destroyed the ignition. i can get it to go through all cycles with a screw driver, it will crank all day but not start. none of the wires were touched except one that has a black wire and a black/white wire and has a plastic connector thing at the end that both wires go into and it sits above the keyhole. also the tail lights are constantly on unless you disconnect the battery. if i can get it to start with a screwdriver fine. i just want the use of my car back. Edited February 19, 2011 by awakethroughmot Quote Link to comment Share on other sites More sharing options...
NorthWet Posted February 19, 2011 Share Posted February 19, 2011 I can't help you at the moment with the major part of your question (ignition), but the taillights being on is almost certainly because the "virgin switch" on top of the steering column is flipped on. This switch allows the parking lights to be turned on while the ignition switch is off. (Almost all new-to-subaru owners ask this question, hence the name.) Quote Link to comment Share on other sites More sharing options...
Cougar Posted February 20, 2011 Share Posted February 20, 2011 There may be some blown fuses or fusible links. I suggest you check those to make sure they are all ok. The fusible links are inside a plastic box mounted on the coolant resevoir. If the fuses are all ok then make sure you have spark getting to the plugs. Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted February 20, 2011 Share Posted February 20, 2011 I cant image anyone trying to steel these cars on a regular basis, no matter now nice they may look. I used to leave the keys in my car all the time and no one gave it a second look. Quote Link to comment Share on other sites More sharing options...
Danny88GL Posted March 27, 2011 Share Posted March 27, 2011 probably the neighborhood teens wanting a joy ride or use it ot go find a nicer car.. Now i want to put an alarm on mine lol just for the remote door unlock (and winter starting) Quote Link to comment Share on other sites More sharing options...
