Scoobywagon Posted February 21, 2011 Share Posted February 21, 2011 So my 88 GL with 3AT is having trouble with upshifts. It will do the 1-2 shift at about 3,000 rpm and the 2-3 shift at about 5,000. Searched around and the consensus is that the first suspect is the Governor valve. Pulled it and checked it over. The plunger feels fine, but there is a little bit of shmutz in a couple of shallow grooves on the shaft. The gear on the end looks ok. However, I'm not sure what apple coring means and I can't find a picture of an apple cored gear. This one looks fairly smooth, but there's an obvious wear line in the gear. If this were a diff, I'd think it was perhaps a little excessive even for 250 kilomiles. Does anyone have a pic or a good description of what apple coring means in this case? Thanks. Link to comment Share on other sites More sharing options...
Turbone Posted February 21, 2011 Share Posted February 21, 2011 (edited) Good gov gear = [] Applecored gov gear = )( There were some pics sometime in the past, but it appears they are gone. I would disassemble the valve and clean it good. Ah, I found a old article. It has pics, but not of a cored out gov. http://web.archive.org/web/20050227203610/www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f50d9b8.15492800/&FileType=Article&File=ARTICLE_3f57fdb83de231.34713659.art Edited February 21, 2011 by Turbone Link to comment Share on other sites More sharing options...
Scoobywagon Posted February 22, 2011 Author Share Posted February 22, 2011 (edited) Thanks, Rob. Much appreciated. Ok, well, I didn't disassemble it because I don't have the tools to do that here. However, I did replace it with a valve from another trans and the problem has gone away. I'll be taking the old one in to the shop with me tomorrow and I'll tear it down and clean it there. Here's what I don't understand. To my fingers, the plungers on both units feel the same. Both have similar wear patterns on the gears, though the new one has at least 60,000 fewer miles on it. The new one works, the old one doesn't. WTFO? Edited February 22, 2011 by Scoobywagon Link to comment Share on other sites More sharing options...
NorthWet Posted February 22, 2011 Share Posted February 22, 2011 A picture of apple-cored driven gear (post#19): http://www.ultimatesubaru.org/forum/showthread.php?t=120067&highlight=governor&page=2 Looks don't mean squat on that valve. Assuming the gear looks ok, disassemble it check it by hand, and then debur/clean it anyway. Link to comment Share on other sites More sharing options...
NorthWet Posted February 22, 2011 Share Posted February 22, 2011 ...Here's what I don't understand. To my fingers, the plungers on both units feel the same. Both have similar wear patterns on the gears, though the new one has at least 60,000 fewer miles on it. The new one works, the old one doesn't. WTFO? The valves are under loads from springs and what not, and they have parts that slide inside of other parts. In my all-to-often experience, unless you disassemble it you can not really assess the movement of the parts. They literally need to move like a "hot knife through butter". (I had also thought about making some genderist remark involving the distaff gender and looks not telling you much, but then I decided it was just the chain-saw fumes affecting my judgment.) Link to comment Share on other sites More sharing options...
Scoobywagon Posted February 22, 2011 Author Share Posted February 22, 2011 Ok, well, in that case, my gear must be good because it looks NOTHING like that. So, I'll continue on with plan a and tear down the valve tomorrow. Link to comment Share on other sites More sharing options...
Scoobywagon Posted February 22, 2011 Author Share Posted February 22, 2011 I decided it was just the chain-saw fumes affecting my judgment.) mmm....chainsaw fumes. Got my RDA of that this morning. Link to comment Share on other sites More sharing options...
NorthWet Posted February 22, 2011 Share Posted February 22, 2011 Ok, well, in that case, my gear must be good because it looks NOTHING like that. So, I'll continue on with plan a and tear down the valve tomorrow. The helical teeth are supposed to be even top to bottom, not saddle-shaped as that example was showing. RE: chain-saw fumes - I had to stop cause the dang elephants said that I was disrupting their tea-party. Stupid elephants; it was obviously coffee. Link to comment Share on other sites More sharing options...
Turbone Posted February 22, 2011 Share Posted February 22, 2011 A picture of apple-cored driven gear (post#19):http://www.ultimatesubaru.org/forum/showthread.php?t=120067&highlight=governor&page=2 Looks don't mean squat on that valve. Assuming the gear looks ok, disassemble it check it by hand, and then debur/clean it anyway. Dang it, I looked for that thread and couldnt find it Thanks NW. Link to comment Share on other sites More sharing options...
NorthWet Posted February 22, 2011 Share Posted February 22, 2011 I call, "King of the Search!" Woo-hoo! Look at me! Link to comment Share on other sites More sharing options...
NorthWet Posted February 22, 2011 Share Posted February 22, 2011 Not that it was much of a contest, Rob. I know that you suffer from CRS. Link to comment Share on other sites More sharing options...
