Mark W. Martin Posted February 22, 2011 Share Posted February 22, 2011 Hello, I have a 97 Legacy GT wagon and I have noticed that when i raise the front passenger side window all the way to the top that it is about an 1/8th of an inch too hi. Then when i try and close the door it hits the metal bezel along the roof and leaves a gap. Any ideas? Thank you, Mark Link to comment Share on other sites More sharing options...
Suzam Posted February 22, 2011 Share Posted February 22, 2011 (edited) You'll need to remove the door panel and adjust the small bracket stops near the top of the door frame that limit the window travel. Loosen the bracket and adjust it when you have the window at the proper closed height. If you are unsure about the panel removal use the search for location of the screws and fasteners. Edited February 22, 2011 by Suzam clarification and poor spelling :/ Link to comment Share on other sites More sharing options...
Mark W. Martin Posted February 23, 2011 Author Share Posted February 23, 2011 Thanks Suzam, That worked! Link to comment Share on other sites More sharing options...
