ernst82 Posted February 22, 2011 Share Posted February 22, 2011 Does my 86 xt turbo need that trip computer that is in the dash? I want to use that area for my boost and air/fuel gauges. Link to comment Share on other sites More sharing options...
skishop69 Posted February 22, 2011 Share Posted February 22, 2011 No, it does not need it. I should warn you against trying to remove it and replace it with something else as the dash/cluster trim is prone to breaking if even looked at the wrong way let alone removed. It was weak out of the box and more so 25 years later..... Link to comment Share on other sites More sharing options...
NorthWet Posted February 22, 2011 Share Posted February 22, 2011 No, it does not need it. I should warn you against trying to remove it and replace it with something else as the dash/cluster trim is prone to breaking if even looked at the wrong way let alone removed. It was weak out of the box and more so 25 years later..... +1 on the breakage issue. Link to comment Share on other sites More sharing options...
ernst82 Posted February 23, 2011 Author Share Posted February 23, 2011 the trim was already broken when i bought the car, I pick on my new trim from subaru this week, so i figured since its already off I might as well fix, replace and upgrade while its still off. Link to comment Share on other sites More sharing options...
Turbone Posted February 23, 2011 Share Posted February 23, 2011 Just curious, how much did you pay for that trim from the dealer? Link to comment Share on other sites More sharing options...
ernst82 Posted February 23, 2011 Author Share Posted February 23, 2011 For the trim plus shipping $88. Link to comment Share on other sites More sharing options...
