Compression test results ???
EA82
Well, I did a compression test. Got 105 / 135, 80/ 140. Wet tested 80 and got 110. Pressure tested radiator w/ no coolant and air escaped from the 80 spark plug hole as fast as I could pump it in the radiator. 80 held pressure, a spoon of oil increased pressure but air from radiator rushes in...What going on?
Edited by Casino Loyale
UGGGH only if they are falling out of the sky!!. give it to me if you throw it out. I have the last ea82 on earth, at least in my region.
sounds like blown head gasket. easy to fix. dont wasete a still good motor if you can fix it yourself. what if you get a junkyard engine and it blows a head gasket?
i have fixed these motors in WAY WAY WAY worse condition.
