Casino Loyale Posted February 23, 2011 Share Posted February 23, 2011 (edited) EA82 Well, I did a compression test. Got 105 / 135, 80/ 140. Wet tested 80 and got 110. Pressure tested radiator w/ no coolant and air escaped from the 80 spark plug hole as fast as I could pump it in the radiator. 80 held pressure, a spoon of oil increased pressure but air from radiator rushes in...What going on? Edited February 23, 2011 by Casino Loyale Quote Link to comment Share on other sites More sharing options...
Idasho Posted February 23, 2011 Share Posted February 23, 2011 if you have air passing from the radiator into a cylinder or vise-versa during a compression test, then you have one of two problems. *bad headgasket or *hole in a cylinder exposing a water jacket Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 23, 2011 Share Posted February 23, 2011 Throw that engine in the scrap heap. It's hosed. Used replacement is cheaper than fixing it. GD Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 23, 2011 Share Posted February 23, 2011 UGGGH only if they are falling out of the sky!!. give it to me if you throw it out. I have the last ea82 on earth, at least in my region. sounds like blown head gasket. easy to fix. dont wasete a still good motor if you can fix it yourself. what if you get a junkyard engine and it blows a head gasket? i have fixed these motors in WAY WAY WAY worse condition. Quote Link to comment Share on other sites More sharing options...
