Dj7291993 Posted February 26, 2011 Author Share Posted February 26, 2011 well, I picked up an impact from sears, 580 ft lbs. If that don't work, Would it be best to cut them, or try loosening it? Link to comment Share on other sites More sharing options...
silverhelme Posted February 26, 2011 Share Posted February 26, 2011 Because I play with automatics more than most people I have a specific socket that I have ground the end down to get rid of the bevel. This allows me to get the most bite on the thin heads even on slightly rounded bolts. At this point I would try this so that you have a little extra bite on those rounded heads. Be sure and use a 6 point socket. Link to comment Share on other sites More sharing options...
NorthWet Posted February 26, 2011 Share Posted February 26, 2011 Once upon a time, they sold (at Sears and elsewhere) a fluid that you could put in your socket that would provide extra grip on the fastener flats. It was essentially a fine grit in a liquid carrier, and the grit took up the slack between socket and fastener. Your head may be too rounded by now to do much good, but a product like this still might help. Link to comment Share on other sites More sharing options...
Dj7291993 Posted February 27, 2011 Author Share Posted February 27, 2011 Got it off. I ended up using a set from sears called bolt-out plus. Basically is a bladed socket that cuts into the side of it. The cutting part is curved, so as you turn, it bites further on. About $15. Wish I could have found it sooner. I'm gonna look it up for the link, and update the op with the solution. Link to comment Share on other sites More sharing options...
davebugs Posted February 27, 2011 Share Posted February 27, 2011 Funny no one had mentioned them. I have a set of the original "Xtractors", Irwin makes them, Sears, Snap-on, Matco, etc. Link to comment Share on other sites More sharing options...
