Arty Posted November 23, 2011 Share Posted November 23, 2011 Bumping this... can anyone give a more precise location of the extra bolt hole? Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 24, 2011 Author Share Posted November 24, 2011 It's higher up on the block, about 3 or 4 inches from the original mounting point towards the left (driver side) rear corner of the block. Link to comment Share on other sites More sharing options...
Bdubya Posted January 4, 2012 Share Posted January 4, 2012 Does anyone have information on the KS89 Knock Sensor?! Of course I couldn't have the cheaper sensor! Its a 1990 Loyale Wagon (non-turbo). Thanks guys! Link to comment Share on other sites More sharing options...
987687 Posted January 4, 2012 Share Posted January 4, 2012 That doesn't have a knock censor. Unless you meant Legacy?? Link to comment Share on other sites More sharing options...
Bdubya Posted January 4, 2012 Share Posted January 4, 2012 987687 said: That doesn't have a knock censor. Unless you meant Legacy?? Then what is this $80 part that come up when i search for a 1990 Subaru Loyale Knock Sensor? part #KS89 My CEL comes and off at what seems to be random times, my mechanice said it maybe my knock sensor.. I need to get my washington state emissions test,however, from what i understand it will be an automatic fail if the CEL is on.. (this is my first test in the state of Washington, NY does a safety check) Link to comment Share on other sites More sharing options...
naru Posted January 4, 2012 Share Posted January 4, 2012 Bdubya said: Then what is this $80 part that come up when i search for a 1990 Subaru Loyale Knock Sensor? part #KS89My CEL comes and off at what seems to be random times, my mechanice said it maybe my knock sensor.. I need to get my washington state emissions test,however, from what i understand it will be an automatic fail if the CEL is on.. (this is my first test in the state of Washington, NY does a safety check) 1990 Turbos only. Link to comment Share on other sites More sharing options...
987687 Posted January 4, 2012 Share Posted January 4, 2012 I'd start by checking what the code is Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 5, 2012 Author Share Posted January 5, 2012 A 1990 model is OBD1, you can hook the test connectors under the dash together and it will flash the codes that are set. I think there are specific instructions in the USRM, or you can probably find them by searching. Link to comment Share on other sites More sharing options...
987687 Posted January 5, 2012 Share Posted January 5, 2012 Fairtax4me said: A 1990 model is OBD1, you can hook the test connectors under the dash together and it will flash the codes that are set. I think there are specific instructions in the USRM, or you can probably find them by searching. ?? Not on a loyale. It isn't OBD anything. It's like the rest of the SPFI cars, the RED LED on the computer itself flashes the codes. Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 5, 2012 Author Share Posted January 5, 2012 Well, nevermind then. I read "Legacy" somewhere and it stuck. Link to comment Share on other sites More sharing options...
987687 Posted January 5, 2012 Share Posted January 5, 2012 I fixed my CEL with electrical tape, although I suppose that wouldn't work in a state that wants it to be off... You could rig it up to turn on when the engine is off, then turn off when the engine runs... That's probably what I'd do... Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 6, 2012 Author Share Posted January 6, 2012 Either way. If the car has a check engine light, there has to be SOME WAY to read the code. You'll certainly get some better info in the older gen section. http://ultimatesubaru.org/forum/forumdisplay.php?f=2 Lots of EA owners here that know their stuff with those models. Link to comment Share on other sites More sharing options...
jarl Posted July 4, 2012 Share Posted July 4, 2012 (bump) One more point to the statistics: '99 OBW running a '95 EJ22 out of an Impreza with no codes related to the knock sensor, but running like crap. SERIOUSLY underpowered at low RPMS (bad enough you may consider turning off the A/C if you need to join the interstate). After 2500 RPM the car has somewhat decent acceleration. The knock sensor looked fine but after removing it I found it had a crack on it's side (see picture). It may be a placebo effect, but it *looks* like I may have gained a few HP after replacing the knock sensor with a Beck Arnley unit Link to comment Share on other sites More sharing options...
Ricearu Posted July 6, 2012 Share Posted July 6, 2012 also, I know from experience that if the knock sensor goes bad to where it doesn't read knock but carries the right resistance, that the computer will advance the timing, hunting for it's limit with fuel given and ping like hell. My 90 did that until I replaced it. I lost a few horse and gained some fuel mileage. Link to comment Share on other sites More sharing options...
95LEGOBW Posted September 4, 2012 Share Posted September 4, 2012 (edited) I was getting the infamous P0325 Knock Sensor code on my 95 2.2 (correction) Legacy Wagon with 199K miles on it. Thanks to FairTax's :banana:post, I decided to tackle this fix. I removed the old sensor, cleaned up the surfaces, then re-installed. Got the code again immediately. (I had disconnected the battery for 10 minutes, in order to clear old codes.) The old sensor had no cracks. I measured its resistance and got 550 ohms. Wiggling around the wire and connector, I found no loss of continuity. In my hands, it didn't seem to be a bad sensor. When installing it, I had even used a torque wrench to tighten it to the lower end of the torque range. Still, I was getting the code. So, I bought a new Knock Sensor online for $13, shipped. (A good price, by the way. NAPA wanted about $50, and Subaru wanted even more.) I measured the new sensor's resistance and got the same reading as the old sensor. I installed the new one, cleared the codes, then went for a long drive. No CEL! The car still seems underpowered, though. On freeway on-ramps, it must be floored to get up to speed in time, and it's best to turn off the AC. I was hoping the new knock sensor would give some power back, but no luck. This car is operating near sea-level -the car is so underpowered that it would be dangerous at higher elevations. I should have mentioned this, too: It's an automatic. Also, we have to run the 10% alchohol blend fuel here, so there's less energy/gallon than real gasoline, but that's all we've had here for years. I run "regular" octane in the Subie. Edited September 10, 2012 by 95LEGOBW typo, incorrect engine - it's a stock 2.2 Link to comment Share on other sites More sharing options...
johnceggleston Posted September 4, 2012 Share Posted September 4, 2012 what size tires do you have? how old are your plugs and wires? air filter? Link to comment Share on other sites More sharing options...
Olnick Posted September 4, 2012 Share Posted September 4, 2012 95LEGOBW said: I was getting the infamous P0325 Knock Sensor code on my 95 2.5 Legacy Wagon with 170K miles on it. Did you--or a previous owner--put the EJ25 in the car? Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 4, 2012 Author Share Posted September 4, 2012 Quote The car still seems underpowered, though. On freeway on-ramps, it must be floored to get up to speed in time, and it's best to turn off the AC. I was hoping the new knock sensor would give some power back, but no luck. I'm glad my write-up helped you find your way in the wild and wonderful world of auto repair! I'd suggest starting a new thread describing your cars troubles in detail. We also need to positively identify the year, and the engine in the car, since the 2.5 wasn't even available until 96. At least not on the U.S. market. Link to comment Share on other sites More sharing options...
95LEGOBW Posted September 10, 2012 Share Posted September 10, 2012 johnceggleston said: what size tires do you have? how old are your plugs and wires? air filter? Tires are 205/55/16, It's a Plus 1 rim size, but tires are same diameter as stock. Plugs & wires have about 10K on them. Air filter is clean. Link to comment Share on other sites More sharing options...
95LEGOBW Posted September 10, 2012 Share Posted September 10, 2012 Olnick said: Did you--or a previous owner--put the EJ25 in the car? Sorry, engine was correct in title, incorrect in the message. It is the stock original 2.2 engine. Link to comment Share on other sites More sharing options...
95LEGOBW Posted September 10, 2012 Share Posted September 10, 2012 (edited) Fairtax4me said: . . . . . We also need to positively identify the year, and the engine in the car, since the 2.5 wasn't even available until 96. At least not on the U.S. market. My mistake, it was correct in the title, but not in the text. It's the stock, original 2.2. Must have had displacment envy and typed 2.5 by mistake. Edited September 18, 2012 by 95LEGOBW Link to comment Share on other sites More sharing options...
95LEGOBW Posted September 18, 2012 Share Posted September 18, 2012 95LEGOBW said: . . . . The car still seems underpowered, though. On freeway on-ramps, it must be floored to get up to speed in time, and it's best to turn off the AC. I was hoping the new knock sensor would give some power back, but no luck. . . . . Source of slowness found: The car had thick rubber OEM floormats. The driver's side mat had slid forward under the gas pedal, restricting the pedal's movement. Fixed mat, and attached it to the seat posts to prevent further problems. Now, the gas pedal goes full travel, and the automatic transmission can be made to downshift when needed. Acceleration restored! It's still a slow car, but it's no longer unsafely slow. Just wanted to close this loop. Thanks for all the help, folks. Link to comment Share on other sites More sharing options...
upDUHcreek Posted September 18, 2012 Share Posted September 18, 2012 I'm at 170k miles in a 99 forester with the SOHC 2.5. I plan on replacing my knock sensor, but wanted to check here to see if any brand sensor will work, or is this like an o2 sensor where I'd be well advised to buy it from a Subaru dealership? Link to comment Share on other sites More sharing options...
mrtoyou7747 Posted September 18, 2012 Share Posted September 18, 2012 I bought mine on Ebay for about $20 works fine for now over a year and a half Link to comment Share on other sites More sharing options...
upDUHcreek Posted September 18, 2012 Share Posted September 18, 2012 Ok, that's good to know. I've got one other thing I'm going to try first, then if that doesn't work, the knock sensor will be next. Oh, and where are my manners? Thanks for your help, and such a speedy reply. Charlie Link to comment Share on other sites More sharing options...
