subie94 Posted February 24, 2011 Share Posted February 24, 2011 (edited) It does have the 2.5 (had both HGs replaced about 2 yrs ago along with other seals replaced,helped him do rear down) and new clutch a yr ago..has about 170k on odometer.. only thing it needs is cat,possiable wheel bearing and a couple small things (side marker,door clips,radio,spot of rust along rear wheel arch,etc) and my friend is asking like $1500-$1600 for it.. is there anything that i need to look for that could be issues down the line (something that this yr leg is know to have issues with) ? will have to inquire about timing belt seeing that the 2.5 is interference engine (am i correct ?) can't wait to get back into Subaru again.. i got a couple pics but not great ones..(will update when i get better ones,couldn't back up enough in garage to get full pic) Edited February 24, 2011 by subie94 Quote Link to comment Share on other sites More sharing options...
Durania Posted February 24, 2011 Share Posted February 24, 2011 Yes, it is an interference engine. Do you have any idea who did the head gasket job or the parts that were used? I would at most get a leak down and/or a compression test done on it. Quote Link to comment Share on other sites More sharing options...
subie94 Posted February 24, 2011 Author Share Posted February 24, 2011 IIRC,my friend (has been working on soobs for years) and his friend (who is a soob dealer mech) did the HG..i think he even had the heads planed too..not sure of parts used (oem vs aftermarket) when i talk to him this weekend,will have to inquire.. Quote Link to comment Share on other sites More sharing options...
subie94 Posted February 24, 2011 Author Share Posted February 24, 2011 just a sneak peak..bad pics really Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 25, 2011 Share Posted February 25, 2011 If they've lasted 2 years the HGs are probably Subaru replacements and are undoubtedly doing fine. Gut the cat put a spacer on the rear O2 sensor and call it good. If it isn't rusting out underneath $1500 is a pretty good deal for needing only minimal work. Quote Link to comment Share on other sites More sharing options...
