one eye Posted February 25, 2011 Share Posted February 25, 2011 Can you run a gen 3 fuel pump on a switch? I had a bit of a wiring issue on butters where some things go grounded out, and now the fuel pump doesnt work anymore, the little box under the dash is good and I have spark but no power the the fuel pump. I wanna know if thsi is a bad idea Ive done it on gen 1's before but not on Gen3's let me know what you think or will it jsut fill up the carb? Jeff Link to comment Share on other sites More sharing options...
nickolai Posted February 25, 2011 Share Posted February 25, 2011 I would say try it as long as you've got a fuel return line to the tank. I had the same issue in my 88 DL where the fuel pump was getting no power. I ran a new wire to it that turns hot when the key in ON and haven't had trouble. First I had a carbed ea81, and now an ea82 w/SPFI in the car. No trouble with either - I do have a return line. Link to comment Share on other sites More sharing options...
NorthWet Posted February 25, 2011 Share Posted February 25, 2011 IMHO, not a good idea as a long term thing. All the control gizmos are there as a safegaurd in case of accident. Link to comment Share on other sites More sharing options...
ruparts Posted February 26, 2011 Share Posted February 26, 2011 hi, i think the fuel pump is grounded inside the ECM, at least for fuel injected models, i had a 87 sedan with fuel inj that the fuel pump quit working. i thought it was not getting power but , i found it was getting power ( turn the key on and it had power for a couple of seconds) that is normal . if you cranked the motor over it had power continually , turned out it was a bad ground in the ecm. i made a separate ground to the body right by the pump and it was fine ever since. Link to comment Share on other sites More sharing options...
