badjaxns Posted February 26, 2011 Share Posted February 26, 2011 My daughter's 86 Brat GL runs out of gas when it has only used about 4 gallons. The float sinks, so the gauge is not much help. The tank has no obvious dents. Any ideas> Link to comment Share on other sites More sharing options...
opus Posted February 26, 2011 Share Posted February 26, 2011 Filter(s), pump? Link to comment Share on other sites More sharing options...
naru Posted February 26, 2011 Share Posted February 26, 2011 Fuel pick-up tube has a hole at the 4 gallon level. Link to comment Share on other sites More sharing options...
brat82 Posted February 28, 2011 Share Posted February 28, 2011 Pickup up tube in tank could also be clogged. I've had a problem with gas delivery, and had to hook up a hose so I could blow back into tank. Remember if you do this to remove the gas cap. Link to comment Share on other sites More sharing options...
badjaxns Posted February 28, 2011 Author Share Posted February 28, 2011 Thanks. I am going to change the filter and drop the tank to look at the pick-up. The pump will be next. Link to comment Share on other sites More sharing options...
