cruise control in 89 gl
if you want to try to cutdown or hybris a harness, i dont see why not, if you understand schematics and electrical.
Some cars came with a dealer installed option, the unit is standalone, and that wold work if you found one at the junkyard.
Yeah, this is factory and integrated into the steering wheel. So i figured i would have to use the whole steering wheel, but i dont even know if the steering wheels are interchangeable. But i know enough about electrical to get by, Im just unsure if cruise from an spfi car will work on a carb car. Also i don't know what vacuum parts i may need but Im pretty sure cruise uses vacuum.
