Anyone with a stock ea82 wagon and a tape measure....
Will you please measure a few things for me? (on a level surface, with stock size tires)
1. From the ground vertically through the center line of the wheel to the fender arch. Front and rear please.
2. From the center of the hub/axle vertically to the fender arch. Again, front and rear.
I'm trying to figure out just how much lift My car has with the current springs on it and I don't have a stock one to compare it to! I know all my lift dimensions but am going to mathematically figure out how much lift I have over the stock geometry. If you could take these measurements for me please so I have some numbers to reference as a baseline I would appreciate it. Ideal situation would be a Loyale 4wd running 175/70 or 185/70/13 tires that is 100% stock in reasonably unloaded condition (not hauling bricks home from Lowe's or something!). Maybe even have a few folks measure and report back to have some close to repeatable numbers, that would be ideal.
Thanks in advance, Spencer
Edited by obk25xt
