bheinen74 Posted March 29, 2011 Share Posted March 29, 2011 When someone wins the lottery, they otta swap one of the FB into a BRAT, then crush the new platform for scrap, all the while video footage of the occurrence for youtube. BRAT will survive on FB soon. For Brat? Link to comment Share on other sites More sharing options...
logic23 Posted March 29, 2011 Share Posted March 29, 2011 the serpentine belt design is a good idea.. it will save many an a/c and alternator bearing due to over tightening. The bad: plastic. Plastic( chinese) parts are the downfall of the automotive industry. VW stared using them in the mid 90's and its been bad new bears since. A lot of American Auto Manufactures use plastic intakes, pulleys....all junk. Intakes warp and cause vacuum and coolant leaks. I have already seen this with subaru. The a/c tensioner pulleys that were on the 2000-2001 + are plastic with a cheaper bearing and I've been replacing them with the earlier metal versions. Link to comment Share on other sites More sharing options...
logic23 Posted March 29, 2011 Share Posted March 29, 2011 Oh yeah a water pump should be driven by its own belt. that way if the serp belt breaks it wont cause the engine to overheat. Link to comment Share on other sites More sharing options...
Durania Posted April 28, 2011 Author Share Posted April 28, 2011 Car and Driver gave a review of the new FB engine. http://www.caranddriver.com/news/car/11q1/examining_subaru_s_new_fb-series_flat-four-car_news Link to comment Share on other sites More sharing options...
bheinen74 Posted April 28, 2011 Share Posted April 28, 2011 (edited) yep the newly debuted Impreza has the FB20, the 2.0 variation. Smaller, lighter, it propels the newest Impreza a little quicker than the older 2.5, even though it has less power, it still scoots and is rated at 36mpg on the highway in CVT form. Those figures best the base Chevrolet Cruze, Chrysler 200, Ford Focus, Mazda3, Nissan Sentra, Suzuki Kizashi, Toyota Corolla, and Volkswagen Jetta - all with automatic transmissions and without all-wheel drive, a feature that traditionally exacts a notable mileage penalty. I hope Subaru goes to the smaller 2.0 in the entire lineup by year 2014. That would give legacy around 35mpg highway when they do. Good job Subaru for going all out for best gas mileage. Edited April 28, 2011 by bheinen74 Link to comment Share on other sites More sharing options...
Subaru_dude Posted April 28, 2011 Share Posted April 28, 2011 I'm excited about the new engine. But is the water pump at the bottom of the motor? If it is it looks like the only way to change it would be from the top, and I'm sure that would require removing the radiator. Link to comment Share on other sites More sharing options...
987687 Posted April 28, 2011 Share Posted April 28, 2011 You can probably get to it from the bottom. Or maybe just have to remove the radiator fan on that side for clearance. A lot better than having to remove all the timing belt stuff. Link to comment Share on other sites More sharing options...
Subaru_dude Posted April 28, 2011 Share Posted April 28, 2011 You can probably get to it from the bottom. Or maybe just have to remove the radiator fan on that side for clearance. A lot better than having to remove all the timing belt stuff. Yeah definitely better than removing all that timing belt crap. I was thinking the catalytic converter running underneath would be in the way of doing the pump from the bottom. Either way I definitely prefer this design over the previous EJ SO FAR. Don't know if the catalytic converter being so close to the oil pan will cause the oil to sludge up. Every Toyota Camry we've ever had has always been a sludge factory because the cat is so close to the oil filter keeping the oil hot. Link to comment Share on other sites More sharing options...
Durania Posted April 28, 2011 Author Share Posted April 28, 2011 Jordan, refer back to the picture on the first page. The water pump is at the bottom right of the motor, where it has been for a long time. I think it wouldn't be bad at all to change. I would think you wouldn't have to remove the radiator. Link to comment Share on other sites More sharing options...
Olnick Posted April 28, 2011 Share Posted April 28, 2011 The water pump is at the bottom right of the motor . . . Just for the sake of accuracy, the water pump is at the bottom right of the photograph. It's actually at the bottom left of the motor. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 29, 2011 Share Posted April 29, 2011 (edited) Just for the sake of accuracy, the water pump is at the bottom right of the photograph. It's actually at the bottom left of the motor. same as Subaru heritage dictates, down left, same as the EA71/EA81 like on Brat. That ea81 was second best subaru engine, no timing belts, non interference like the ej22 of early. yay Subaru of America finally gives us what we have asked for But they need make them Small like tiny, and have aFWD all the time, with a push button for AWD Engineers here looking please note, that a 2.0 FB coupled to the original 4spd dual range in front drive mode will get 42mpg easy. do you watch my posts???? add 5th gear you get 45mpg......get this then add 6th gear OD get 50mph..... but no you engineers do not follow enough of this board, but you are trying for mpg so follow more, mkay .............bh Edited April 29, 2011 by bheinen74 Link to comment Share on other sites More sharing options...
Durania Posted April 29, 2011 Author Share Posted April 29, 2011 I must be misunderstanding. The EA81 was on the right side of the engine, as facing it from the front. EJ engine: FB: All are pretty much the same location. Link to comment Share on other sites More sharing options...
Olnick Posted April 29, 2011 Share Posted April 29, 2011 I must be misunderstanding. The EA81 was on the right side of the engine, as facing it from the front. For clarity and consistency, directions (left & right) on a vehicle are always given from the point of view of the driver sitting behind the steering wheel! Link to comment Share on other sites More sharing options...
Durania Posted April 29, 2011 Author Share Posted April 29, 2011 (edited) The one day out of the year that I can get dyslexic. Edited April 29, 2011 by Durania Link to comment Share on other sites More sharing options...
bheinen74 Posted April 29, 2011 Share Posted April 29, 2011 ahhh...down by the left head, by the left exhaust...left right left right,... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 4, 2011 Share Posted June 4, 2011 Questions what are all the plugs for the cam sprockets? Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 4, 2011 Share Posted June 4, 2011 Oil pressure control valves for the variable cam timing. Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted June 4, 2011 Share Posted June 4, 2011 As an owner of an engine with variable cam timing, I can tell you that it's the nuts. When it's not broken. Link to comment Share on other sites More sharing options...
AWDfreak Posted June 5, 2011 Share Posted June 5, 2011 For those of you that worship the black Subaru Tokyo Roki oil filters, they're back for the FB engine only in North America. It's part number 15208AA130. I sure hope they'll use it for the whole FB engine lineup, Tokyo Roki makes excellent oil filters! http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2165966 It is sadly, not compatible with the EJ engines, but I have high hopes for the Subaru FB engine Link to comment Share on other sites More sharing options...
Durania Posted June 5, 2011 Author Share Posted June 5, 2011 Dang. Would love to have switched back to the black filters. Link to comment Share on other sites More sharing options...
bheinen74 Posted June 5, 2011 Share Posted June 5, 2011 Is this Subaru admitting some fault with former filters of some sort, that they go back to what they know is best for the newest boxer engines? perhaps. For those of you that worship the black Subaru Tokyo Roki oil filters, they're back for the FB engine only in North America. It's part number 15208AA130. I sure hope they'll use it for the whole FB engine lineup, Tokyo Roki makes excellent oil filters! http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2165966 It is sadly, not compatible with the EJ engines, but I have high hopes for the Subaru FB engine Link to comment Share on other sites More sharing options...
95legwagon Posted November 10, 2011 Share Posted November 10, 2011 that engine is pretty. i like it lol this is the ONE n ONLY time a guy should say pretty imo. very different looking yet very similar. thumbs up in my book. Link to comment Share on other sites More sharing options...
987687 Posted November 10, 2011 Share Posted November 10, 2011 this is the ONE n ONLY time a guy should say pretty imo. Why is that? I can't say that my girlfriend is pretty? Link to comment Share on other sites More sharing options...
bheinen74 Posted November 10, 2011 Share Posted November 10, 2011 Don't call the GF a FB fat bieeech. lol wish i had both, either. Link to comment Share on other sites More sharing options...
cal_look_zero Posted November 10, 2011 Share Posted November 10, 2011 Hmmm... wonder if we'll see a nice price drop on the 257s now. I certainly hope so... Link to comment Share on other sites More sharing options...
