Goatboy Posted March 3, 2004 Share Posted March 3, 2004 85 GL 4wd Wagon won't go anywhere unless its in 4wd. What could be wrong? Not mine, one I might buy. --GoatBoy-- Link to comment Share on other sites More sharing options...
ShawnW Posted March 3, 2004 Share Posted March 3, 2004 Broken front axle. Link to comment Share on other sites More sharing options...
Goatboy Posted March 3, 2004 Author Share Posted March 3, 2004 Wouldn't that make a god awful sound at freeway speeds or turning or any speed at all for that matter?? --GoatBoy-- Link to comment Share on other sites More sharing options...
mcbrat Posted March 3, 2004 Share Posted March 3, 2004 pop the hood put in D or 1st gear and 2wd with park brake on get out and see if axles are spinning. if axles are spipnning, check the axle nut. if it's spinning, then hub is stripped (very little noise). if nut not spinning then CV is totally out and should make lots of noise). if axles not spinning, then internal problem. replace trans. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 3, 2004 Share Posted March 3, 2004 Check to see if it HAS any front axles. If one was removed, and the outer cup used to install the wheel, then you would get no sound. A broken axle should indeed make a lot of noise. Something like an impact wrench. The hub being stripped would initially make noise, but once ground up sufficiently, might quiet down a bit... should still be awful loose, and the wheel would wobble a bit I would think. GD Link to comment Share on other sites More sharing options...
Hondasucks Posted March 4, 2004 Share Posted March 4, 2004 Although when the balls fall out and teh boot stays intact enough to hold the axle in place they don't make THAT much noise lol (happend on my 84) Link to comment Share on other sites More sharing options...
