tbox56 Posted March 4, 2011 Share Posted March 4, 2011 Are all of the R160 diffs the same, as far as them accepting the 25 spline 26mm dia axle ends? I use these diffs in kit cars that I build and have been using the Forester diff with the 4:11 gear ratio and the viscus LSD. I am intrested in using one with the clutch pack LSD but not sure if the axles will fit. Thanks for the help, Tom Link to comment Share on other sites More sharing options...
Scoobywagon Posted March 5, 2011 Share Posted March 5, 2011 As far as I know, all the R160s are externally identical with the only differences being the gearing inside. Having said that, 4.11 is the most common gear set, as near as I can tell, so you shouldn't feel like you need to limit yourself to the Foresters. Link to comment Share on other sites More sharing options...
NorthWet Posted March 5, 2011 Share Posted March 5, 2011 I would defer to Scoobywagon on this unless my memory gets corroborated, but IIRC, there is a difference as far as side-bearing retainers and matching stub-axles. This makes it so that axles have to match the stub-axle type, and there may be differences as to what stub-axles fit which diff "chunks". This is meant to be more of a "I think there is a difference" post rather then me saying that I know what the differences are. Link to comment Share on other sites More sharing options...
x777 Posted March 5, 2011 Share Posted March 5, 2011 The EUDM and JDM rears have mechanical lsd, but require the lsd type axles. Link to comment Share on other sites More sharing options...
tbox56 Posted March 6, 2011 Author Share Posted March 6, 2011 So, the mechanical LSD R160 diff will not accept the axle stub that fits in the viscous LSD R160 diff, is that correct? Thanks, Tom Link to comment Share on other sites More sharing options...
edrach Posted March 6, 2011 Share Posted March 6, 2011 This came up with the search function; might be useful. http://www.ultimatesubaru.org/forum/showthread.php?t=107682 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 6, 2011 Share Posted March 6, 2011 (edited) All the clutch-type LSD's here in the US are setup for bolt-in stubs that are not part of the DOJ cup like the Forester axles you have been using. Thus to do this I think you will have to get one from some other country..... or use first gen Legacy axles. There are Helical LSD's out there - probably in 4.111 - that could be sourced. They aren't cheap but they do exist. GD Edited March 6, 2011 by GeneralDisorder Link to comment Share on other sites More sharing options...
