andyduff Posted March 8, 2011 Share Posted March 8, 2011 Thanks in advance for any advice: I have a 2002 Subaru Legacy GT Limited with about 90k on it. I've noticed the engine vibrates a little when I start it in cold weather - no big surprise there - but vibrates A LOT when the engine is still cold and I'm idling with the car in drive. I've had it tuned up recently and a couple mechanics have said things look good. Any idea what could be going on or what I can do to fix it? Not a huge issue but annoys the hell out of me! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 8, 2011 Share Posted March 8, 2011 Did this issue start immediately after the tune up? If not, how long ago was the tune up and how long would you say it has been doing this? What was replaced during the tune up? Quote Link to comment Share on other sites More sharing options...
davebugs Posted March 8, 2011 Share Posted March 8, 2011 NGK Plugs? OEM wires? Those would be the first things to check. Quote Link to comment Share on other sites More sharing options...
nipper Posted March 8, 2011 Share Posted March 8, 2011 What did they call a tuneup? Quote Link to comment Share on other sites More sharing options...
andyduff Posted March 8, 2011 Author Share Posted March 8, 2011 In October of 2010 I had head gaskets replaced along with spark plugs and spark plug wires because there was a crack in head gaskets. At that time they also replaced water pump, thermostat, timing belt and timing belt tensioner. A couple months later I had it in to a different mechanic for a tune up because of the vibration - which was present prior to all the work above and was much better after it - and I think they just checked spark plugs and wires. Quote Link to comment Share on other sites More sharing options...
nipper Posted March 9, 2011 Share Posted March 9, 2011 Original drive axles? Quote Link to comment Share on other sites More sharing options...
nipper Posted March 9, 2011 Share Posted March 9, 2011 Check the tranny mount Both my subarus idle as smooth as silk (dont kno9w about the Justy yet) Quote Link to comment Share on other sites More sharing options...
andyduff Posted March 10, 2011 Author Share Posted March 10, 2011 Sorry for the confusion. The vibration is happening when the engine is cold and I'm stopped at a red light, for example. Not so much when I'm in park, and goes away once the car is warmed up. I had the transmission flushed a few months ago. So the verdict is put in NGK plugs, OEM wires and check mounts and axles? Thanks! Quote Link to comment Share on other sites More sharing options...
davebugs Posted March 10, 2011 Share Posted March 10, 2011 Sounds like a plan. Remember OEM plug wires only on a 2.5. The order you try things is up to you. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted March 10, 2011 Share Posted March 10, 2011 Sounds like a plan. Remember OEM plug wires only on a 2.5. The order you try things is up to you. Yes, OEM plug wires, or Bosch, I have had good performance from Bosch wires. Bosch and OEM wires cost about the same. It is the cheapie wire sets from the auto part stores that perform badly and cause problems. Quote Link to comment Share on other sites More sharing options...
