xbeerd Posted March 9, 2011 Share Posted March 9, 2011 I am assuming yes to be the answer, but the 00 legacy and outback fenders and hood would bolt up the same on each model right? (model meaning an Outback hood or fender could bolt right up to a Legacy since they are basically the same platform Link to comment Share on other sites More sharing options...
Subie Gal Posted March 10, 2011 Share Posted March 10, 2011 not necessarily Outback vs Legacy = different front bumper beams (using subaru's parts catalog to reference) And that usually means - no. they're not the same. the 00 Legacy vs outback hoods appear to be the same the fenders however, differ. could just be a slight trim issue, or could be a complete no go. I cannot tell for sure without trying an install. Hopefully someone has tried this before and has more insight? Hope this helps a little bit! Link to comment Share on other sites More sharing options...
xbeerd Posted March 10, 2011 Author Share Posted March 10, 2011 my guess is its just the trim, lookin at the outback fender, it looks as you could remove the plastic and put on the legacy trim. might have a few extra holes from the outback plastic attachment. hmm. well, i'll find out on sunday when the guy comes to look at the stuff. Link to comment Share on other sites More sharing options...
idosubaru Posted March 10, 2011 Share Posted March 10, 2011 subaru's opposed forces website is a really good resource for this. it shows different part numbers for legacy and outback fenders. it shows the same part numbers for foresters with different trims (S and L), which i've interchanged before by just swapping trim. Link to comment Share on other sites More sharing options...
Subie Gal Posted March 10, 2011 Share Posted March 10, 2011 I'm using Subaru's EPC software as I work for Subaru. As the 2 models use different bumper beams, the fenders and bumpers are likely not the same Hoods yes. But the other bits may not be compatible without swapping the beam/bumper/fenders. Just like the early WRX here in the USA 2002-2007 The Sedan and Wagon use the same hoods. But the bumpers/fenders are not compatible without swapping all components. Link to comment Share on other sites More sharing options...
