Naked Buell Posted March 12, 2011 Share Posted March 12, 2011 So I found out that I had no power to the coil while cranking so she starts no problem but for some reason the starter is binding even after the engine is running. I changed the step to the EA 82 flywheel specs and I don't understand what is going on. The starter only goes in one way without any adjustment. I even put the starter in from my brat thinking it was the starter and it did the same thing. Does anybody have any ideas?????????? Link to comment Share on other sites More sharing options...
Crazyeights Posted March 12, 2011 Share Posted March 12, 2011 Try putting a .090" washer between the starter and the trans (both bolts). Standard flat washer should be close enough. Link to comment Share on other sites More sharing options...
