coach9 Posted March 13, 2011 Share Posted March 13, 2011 Got this code when it failed emission test in Maryland,anyone know what it is? Link to comment Share on other sites More sharing options...
davebugs Posted March 13, 2011 Share Posted March 13, 2011 Search a little. I'm thinking that may be one of the symptoms of the fuel filler tube. Have you replaced yours? Link to comment Share on other sites More sharing options...
coach9 Posted March 13, 2011 Author Share Posted March 13, 2011 I googled and found it was low fuel pressure,so u r on the right track.Where do i find the fuel filter tube on the 2.5? Link to comment Share on other sites More sharing options...
davebugs Posted March 13, 2011 Share Posted March 13, 2011 Fuel FILLER tube. Where you put the gas in. Often rot out at the bend at the bottom. Link to comment Share on other sites More sharing options...
coach9 Posted March 13, 2011 Author Share Posted March 13, 2011 I will Check that tube I will be putting in a new fuel filter. Link to comment Share on other sites More sharing options...
davebugs Posted March 13, 2011 Share Posted March 13, 2011 That tube is a dealer only item. Also need to know what year or "style" Changed around 97-98 IIR. What changed (again from memory) is rally the EVAP connections up towards the top. I believe the "plumbing" changed when the EVAP canister was moved to behind the RR wheel well. Link to comment Share on other sites More sharing options...
edrach Posted March 14, 2011 Share Posted March 14, 2011 http://www.helpforcars.net/obd_codes/p1440.html Link to comment Share on other sites More sharing options...
