So i finally made the jump to a 2003 2.0 turbo wrx. The car was wrecked and I need to know what years of imprezas will work for donor cars. The wreck took out the section from the drivers headlight back to the strut tower. The frame horn is ok and the strut tower is ok.
I wasn't sure where to post it. Thanks all.
its not the body parts im looking for its the stamped pieces that the fender,core etc support are all part of. Didn't know if earlier imprezas would work. Ive seen swaps where a 96 has the front end of a later impreza.
The outback impreza is where all the WRX stuff is going. The OB impreza has high miles but a SOLID body. They are both wagons. The WRX was a one owner (103,XXX miles) car that looks like no one has ever sat in it except the driver. If I was able to find the front drivers side body panels I was going to put all the worn out OB impreza stuff in the wreck and make a beater. I know little to nothing about imprezas body differences etc. Thanks for the infos. How are the wagon fenders different? Longer? I saw the lower control arms are different too.
