afewsubarus Posted March 15, 2011 Share Posted March 15, 2011 I have an 82 brat auto. I would like to put in a manual which transmissions work for the swap? Link to comment Share on other sites More sharing options...
Dj7291993 Posted March 16, 2011 Share Posted March 16, 2011 well, I think the brat is the same. It would be easiest if you get one out of the same engined car (I assume EA81), but I think you can make an EA82 fit with a little bit of working. I just swapped over an 87 gl coupe. Got lucky enough to find one with the same year at the junkyard, it was a wagon. Bolted right up. Just make sure you get ALL the bolts, as some are different. Also, on mine, the front-half of the drive-shaft is a different length, and the diff is has a different ratio. Of course, if it's fwd, that's not an issue. Also, you need the plastic console pieces (well, don't "need" them, but I'd recommend them). Link to comment Share on other sites More sharing options...
