sunset Posted March 15, 2011 Share Posted March 15, 2011 Hey yalls, First post by the way.Anyways.I have a 86 subaru GL.The computer light blinks 2 long 5 short (like morris code).What does this mean? So i only saying what my cousin is telling me to write idk if what is above makes sense to you,If it doesent feel free to ask. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted March 15, 2011 Share Posted March 15, 2011 What part of Oregon are you in? What are your symptoms? I have a manual, but I dont know if that will help with the computer lights... Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 What part of Oregon are you in? What are your symptoms? I have a manual, but I dont know if that will help with the computer lights... There really is no symptoms.The car runs great infact.And im beaverton,97007 area code. Link to comment Share on other sites More sharing options...
xbeerd Posted March 15, 2011 Share Posted March 15, 2011 is your CEL on? Trouble Codes 83 - 88 Subaru carb models 11 Ignition pulse system/crank angle sensor(87 & later) 12 Ignition pulse system (1983 only)/Starter switch (84 & later) 13 Crank angle sensor or circuit 14 Vacuum switches stay on or off (1983 only)/Duty solenoid or circuit(1983 to 1985)/Injectors 1 & 2 (87-up) 15 Solenoid valve stays on or off (1983 only)/Coasting Fuel Cut (CFC) system (1983 to 1985 ) 16 Feedback system (1983 to 1985 models) 17 Fuel pump and automatic choke (1983 to 1985 carbureted) 21 Ignition pulse system (1983 only)/coolant temperature sensor or circuit (1983 to 1985 carbureted) 22 Ignition pulse system (1983 only)/Vehicle speed sensor or circuit or VLC solenoid valve or circuit. (1984 to 1988 carbureted) 23 Oxygen sensor or circuit (1983 to 1988)/pressure sensor or circuit (1983 to 1985) 24 Vacuum switches stay on or off (1983 only)/coolant temperature sensor or circuit, or Idle-up solenoid or circuit (1984 to 1988 carbureted) 25 Manifold vacuum sensor or circuit/coolant temperature sensor or circuit on 1984 models)/float chamber vent solenoid valve or circuit (1983 to 1985) 32 Coolant temperature sensor or circuit (1983)/Oxygen sensor or circuit (1984 to 1988) 33 Main system in feedback (1983 to 1988)/Vehicle speed sensor or circuit (1983 to 1985) 34 Choke power stays on or off (1983)/EGR system solenoid or circuit (1883 to 1988) 35 Canister purge solenoid or circuit (1983 to 1985) 41 Vacuum switches stay on or off (1983 only)/Feedback system (California models 1983 to 1985) 42 Vacuum switches stay on or off (1983 only)/clutch switch or circuit (1983 to 1988) 43 Choke power stays on or off (1983) 46 Radiator fan control (1983 to 1985) 52 Solenoid valve control system or clutch switch 53 Fuel pump circuit or Altitude compensator switch 54 Choke control system 55 Upshift control or EGR sensor 56 EGR system 62 Exhaust Gas Recirculation (EGR) solenoid valve control or Idle-up system 63 Canister solenoid valve or circuit/Idle-up system 64 Vacuum line control valve or circuit 65 Float chamber vent control valve circuit 71 Ignition pulse system 73 Ignition pulse system 74 Ignition pulse system 84 - 86 Fuel Injected models 11 Ignition pulse 12 Starter switch off 13 Starter switch on 14 Airflow meter or circuit 15 Atmospheric pressure switch - fixed value 16 Crank angle sensor or circuit 17 Starter switch or circuit 21 Seized airflow meter flap 22 Pressure or vacuum switches - fixed value 23 Idle switch - fixed value 24 Wide open throttle switch - fixed value 25 Throttle sensor idle switch or circuit 31 Speed sensor or circuit 32 Oxygen sensor or circuit 33 Coolant sensor or circuit 34 Abnormal aspirated air thermosensor 35 Air flow meter/EGR solenoid switch or circuit 41 Atmospheric pressure sensor or circuit 42 Fuel injector - fixed value 43 KDLH control system 46 Neutral or parking switch or circuit 47 Fuel injector 53 Fuel pump or circuit 55 KDLH control system 57 Canister control system 58 Air control system 62 EGR control system 88 TBI control unit Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 is your CEL on? We dont know what a CEL is lol. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted March 15, 2011 Share Posted March 15, 2011 Check engine light I sent you a visitor message, I can come look at your subaru if youd like, Im in the Aloha Oregon area. Link to comment Share on other sites More sharing options...
xbeerd Posted March 15, 2011 Share Posted March 15, 2011 LOL. sorry about that, the CHECK ENGINE LIGHT. it probably says check engine on it, my cars a 92, the light is on the right side of the indicators that run along the area under the gauges. i dont know exactly where it is on the 86. if its on, you'd probably know. Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 Check engine light I sent you a visitor message, I can come look at your subaru if youd like, Im in the Aloha Oregon area. No thanks bud.But thats pretty cool of you to ask to come out and take a looks lol.Thanks a bunch anyways. LOL. sorry about that, the CHECK ENGINE LIGHT. it probably says check engine on it, my cars a 92, the light is on the right side of the indicators that run along the area under the gauges. i dont know exactly where it is on the 86. if its on, you'd probably know. lol we was trying to figure out what a cel is...tah it came to me lol.im a 14 year old mechanic. And yes the cel is on. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted March 15, 2011 Share Posted March 15, 2011 Do you have a subaru manual? Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 Do you have a subaru manual? We do. But the codes arent in there. Link to comment Share on other sites More sharing options...
MilesFox Posted March 15, 2011 Share Posted March 15, 2011 If your car is SPFI fuel injected, this is your code. is your car a 3-door? http://www.economysuperstar.com/milesfox/subaru/service/ecu.htm Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 If your car is SPFI fuel injected, this is your code. is your car a 3-door? http://www.economysuperstar.com/milesfox/subaru/service/ecu.htm Its split port fuel injected.But it has coarboators.So it says is has carberators on it.But it really doesent so yeeeaaaaahhh.I only write what the mechanic writes lol.and its a 5 door. Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 So really we are just trying to identify the problem.The problem being were trying to figure out what 2long flashes and 5 short flashes means.Weather or not thats just the way it blinks or if thats one of many codes.If it is a code trying to figureo ut what that code is.see what im sayin? Link to comment Share on other sites More sharing options...
92_rugby_subie Posted March 15, 2011 Share Posted March 15, 2011 You really should let someone come look at that... Im thinking that with Mile Fox's guide, you are looking at: "25 Throttle Sensor Idle Switch or Circuit" This would be your 2 long blinks and then 5 shorts (being 25) Thats for SPFI This is for carburetors: "25 Manifold Vacuum Sensor or Circuit (1985-1988 Models)" Sorry for the confusion Link to comment Share on other sites More sharing options...
92_rugby_subie Posted March 15, 2011 Share Posted March 15, 2011 Edited last posting ^ Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 You really should let someone come look at that... Im thinking that with Mile Fox's guide, you are looking at: "25 Throttle Sensor Idle Switch or Circuit" This would be your 2 long blinks and then 5 shorts (being 25) Thats for SPFI This is for carburetors: "25 Manifold Vacuum Sensor or Circuit (1985-1988 Models)" Sorry for the confusion DUDE YOU ARE A GENIOUS!!!!!! That makes total sense 25 I got ya! lol thats pretty smart lol.Ok now i think were getting some were. Link to comment Share on other sites More sharing options...
Dj7291993 Posted March 15, 2011 Share Posted March 15, 2011 If you've got some of these guys offering to come help you, I'd take it man. These guys know what they are talking about. Link to comment Share on other sites More sharing options...
sunset Posted March 15, 2011 Author Share Posted March 15, 2011 If you've got some of these guys offering to come help you, I'd take it man. These guys know what they are talking about. I think we have allready heard what we want to hear budday.And im sure it's no big deal something little.But the car rubs fine.But im allso no auto mechanic.Only a 14 year old computer nerd writing what a 48 year old auto nerd tells me to. Link to comment Share on other sites More sharing options...
