SUBARU3 Posted March 15, 2011 Share Posted March 15, 2011 Hey guys....is there a single, common culprit that causes the gear shifter to rattle when cruising? I know on the Gen 1s it's usually the bushing at the base if the shifter. There are alot of bushings and insulators in the shifter , I just know it's not all of them. Car has 73K 1995 Impreza 2WD 5 speed Thanks, Todd Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 15, 2011 Share Posted March 15, 2011 There a are a half dozen or so little bushings in the shift linkage that can wear and become loose and possibly rattle. Check the bolt that attaches the shift lever to the linkage. That one rattles a bit every now and then on mine. I put some thick grease in the spacer and all over the bolt and it quit for a while. If that doesn't help yours the other bushings might be worn out and need replacement. Link to comment Share on other sites More sharing options...
SUBARU3 Posted May 11, 2012 Author Share Posted May 11, 2012 Anyone have the part #s needed to spruce up an Impreza shifter? Thanks, Todd Link to comment Share on other sites More sharing options...
Durania Posted May 11, 2012 Share Posted May 11, 2012 http://opposedforces.com/parts/impreza/us_g10/type_2/manipulation/manual_gear_shift_system/illustration_1/ Link to comment Share on other sites More sharing options...
SUBARU3 Posted May 11, 2012 Author Share Posted May 11, 2012 WOW...just what I needed. Thanks! Todd Link to comment Share on other sites More sharing options...
