Does this look right? 86 adj susption pics
Goto "Springs" folder
http://f1.pg.photos.yahoo.com/ph/subi81@sbcglobal.net/my_photos
are those bolts suposed to be in there or are the two plates suposed to contact each other.
The car seems to be about 1 inch to high in the front, even compared to my brothers 87. I remedied this gaser look buy jacking up the rear but even with an RX swaybar out back it is too leany for my taste. Makes my car look like a late ninties dodge ram, to much wheel space.
I guess I am asking if I can take out the 2 bolts that are in there.
Thanks
Even though those are an aftermarket brand they have been messed with beyond that. The two nuts in between the perch and adjustment tab have been added. Looks like they may have even added a different bolt. It's much longer than stock.
Just took a look at my 86 Brat. I have the same type struts from Monroe. Installed them myself over a year ago (and even followed instruction sheet!). The bolts on mine are shorter and there are no nuts below the bottom plate. On mine, the blue welded on nut is as pictured in your setup. The spacing distance between the spring perch and the bottom plate in your pic is about equal to mine.
I agree with Qman, something ain't right.
The bolts that stick down are almost 3 inches long. seems out of place
calebz if I ever do replace them they are yours, they seem to be functioning correctly, not leaking any oil
I guess I will have remedy it, does anyone have a pic of their setup, I just want to put it back to how it is supposed to be.
Thanks for the replies!
