drugh Posted March 16, 2011 Share Posted March 16, 2011 Ive got a 92 loyale 4WD wagon and my shocks are worn out. I have replaced shocks in previous loyales with new Monroes (kept the stock springs) and I was not overly satisfied with the results. This combination is still pretty mushy in the corners, especially with several people or lots of gear in the car. I am considering a set of King Springs from Primitive racing, and I am wondering if the standard height springs will make too much positive camber in the front tires for daily driver use. I would be ordering the standard height springs, which still lift the car "slightly." I wouldn't be worried except the EA82s already have a lot of positive camber in the front. I know there has been lots of research with other springs and suspension for EA82s. I also know that a loyale is never going to handle that great. I am looking for some sort of improvement, and as long as I dont burn through tires I will be happy. Thanks Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 16, 2011 Share Posted March 16, 2011 Its not only the positive camber in the front that can eat tires. These cars also run a lot of negative toe as well which isn't good for handling, just to help prevent the wear of tires. Now if you run a positive camber with zero toe, then yes, you'll get outside edgewear. Are you in North Bend, WA? I work over in Kirkland at Clark's Wheel Alignment and guess what I specialize in.... Link to comment Share on other sites More sharing options...
drugh Posted March 16, 2011 Author Share Posted March 16, 2011 So you think you can set up the alignment with the King Springs so that it wont eat tires? You might just be seeing my car here in a couple months. Yes I am in North Bend WA. Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 16, 2011 Share Posted March 16, 2011 So you think you can set up the alignment with the King Springs so that it wont eat tires? You might just be seeing my car here in a couple months. Yes I am in North Bend WA. Sure can! Just shoot me a PM when you're ready to get it done. Link to comment Share on other sites More sharing options...
