Idasho Posted March 17, 2011 Share Posted March 17, 2011 What is everyone using for brake lines on lifted rigs? Are you having them made, or is there something available off the shelf that will bolt right in for a lifted EA81? Thanks Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 18, 2011 Share Posted March 18, 2011 the stock lines should be long enough. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 19, 2011 Share Posted March 19, 2011 the stock lines should be long enough. This is completely dependant on what type of lift. I have a 6 inch lift on my 84 GL I rerouted my hardlines to a new hole, lower in the inner feder. I also unclipped the lines from the strut mounts, and ziptie them higher up. Quote Link to comment Share on other sites More sharing options...
monstaru Posted March 19, 2011 Share Posted March 19, 2011 i simply "re-aligned " the brakelines with my last lift(6").just slightly reshaped them whilst pulling from the inner fender well....also cut the brake tab lines on the strut and used zipties. as amatter of fact i think every set of brakes on a car i have driven have beeen free;d from the strut.makes changing struts easier and less hzssle... cheers, b Quote Link to comment Share on other sites More sharing options...
Idasho Posted March 20, 2011 Author Share Posted March 20, 2011 Thanks guys. Im lifting just 2 inches, and would like to avoid modifying the hard lines in any way. So if I disconnect the soft line from the strut I should have enough length? Quote Link to comment Share on other sites More sharing options...
Tosh Posted March 20, 2011 Share Posted March 20, 2011 Thanks guys. Im lifting just 2 inches, and would like to avoid modifying the hard lines in any way. So if I disconnect the soft line from the strut I should have enough length? Yep, and some to spare. I did the same with my 4 inch lift. Quote Link to comment Share on other sites More sharing options...
Idasho Posted March 20, 2011 Author Share Posted March 20, 2011 thanks! Quote Link to comment Share on other sites More sharing options...
