need a lil help
Can anyone guess the year of this car. This is what the ad said:
87? Subaru 4WD
No title or key. Ran when parked, was told needs brake work and exhaust was noisy. New tires (13"), needs cleaning, not pretty.
Im guessing 90 or 91...
'89 or older - it's got a Dual Range. Specifically it's an '87 to '89 because of the dash and steering wheel style.... and lack of automatic belts..... hard to say which of those years as they were all very similar.
13" wheels and tires are standard on all EA series vehicles. Anything larger is VERY rare. A few examples have been found but they literally number less than a dozen sets that I've witnessed as factory EA wheels or optional wheels. Pug's not included of course....
Edited by GeneralDisorder
This car is a 1987 with gl-10 seats.
the steering wheel is 1987 specific. 85-86 was more squarish, and 88 thru the loyale had the long horizontal middle, the dildoey steering wheel.
1987 is somewhat specific to its year, as this was a tansition year. The wiring harness is schematically similar to a 1988, but has connectors similar to a 1986. The sensors and distributor are compatible with 86.
by 88, the design remained considtent through the 1994 loyale.
The instruments have a green illumination.
if you replace your engine, the harness form the intake will swap over to an 88+ manifold, and the manifold itself swaps. The connector for the engine harness is similar to 1986. If you use a motor from 88 or later, you need your original intake, or at least swap your87 harness to the 88+ intake.
The GL-10 was the luxo trim package, and the seats were more plush with velour and the buttons, where the regular gl had more of a tweedish type fabric.
the gl-10 seat has a height adjust lever on the side. pulls up or down, extends for leveage.
Check the vin plates from the dash and the door sill. what is the build date?
can the dude produce a title, or is this a parts car?
Subaru Vehicle Identification Decoder
Look up your vin number online
First 3 Digits
JF1 Passenger Vehicle
JF2 Multi-Purpose Passenger Vehicle (MPV)
Fourth Digit Model Line
A Subaru XT and Loyale
K Subaru J Line
Fifth Digit Body Type
A Justy
B 4-dr 81-84
C 4-dr 85-89
F HatchBack 81-89
G 3-dr Coupe 86-89
K Touring Wagon 89
M Wagon 81-84
N Wagon 85-89
R Brat 81
T Brat 82-85
U Brat 86-87
W Hardtop 81-84
X XT 85-89, XT6 88-89
Sixth Digit Engine Type
1 1300
2 1600
3 1600 4wd
4 1800
5 1800 w/o air suspension
7 1800 4wd with air suspension
8 2700
9 2700 4wd with air suspension
Seventh Digit Model Designation
1 STD Hatchback
2 DL
3 GL 81-90, RS, Justy
4 GLF 81-82, GL-10 85-89, Xt6 88-89
5 86 Turbo, GL-10 Turbo 87-89, GL full-time 4wd 3-door 87
6 Turbo RX
7 GL Turbo 87-89
Eighth Digit Weight Class and Restraint Type
A Less then 3000 lbs GVWR
B 3001-4000 lbs GVWR with Passive Restraint
1 Less then 3000 lbs GVWR
2 3001-4000 lbs GVWR with Passive Restrain
Ninth Digit Check Digit
Tenth Digit Vehicle Model Year
A 4spd MT
B 5spd MT
C 3AT
D 4spd 4wd MT 81-84
D 5spd 4wd MT 85-89
E 4spd 4wd Dual Range MT 81-84, 85-89 Hatchback, 85-89 Brat
E 5spd 4wd Dual Range MT 85-89
F 3AT 4wd
G Full Time 4wd MT
H 4EAT Full Time 4wd
4 4spd 4wd 87 Hatchback
Last Digits
002001 & after Touring Wagon
100001 & after Hatchback
200001 & after 4 Door Sedan
300001 & after Hardtop 81,84, XT, XT6
400001 & after Wagon
500001 & after Brat
700001 & after Justy
800001 & after 3-Door
Subaru VIN code
Position Sample Description 1 4 World Manufacturer Identifier 2 S 3 4 4 B Line type 5 T Body style 6 6 Engine type 7 1 Model identifier 8 C Restraint type 9 X Check digit 10 3 Model year 11 7 Plant of manufacturer & transmission type 12 1 Sequential number 13 0 14 8 15 3 16 8 17 5
Line types
The line type is specified in character four of the Subaru VIN for passenger cars.
VIN Code Description A Alcyone/XT/XT6 B Legacy/Baja C Alcyone SVX G Impreza S Forester
Body styles
The body style is specified in character five of the Subaru VIN for passenger cars.
VIN Code Description C Impreza Sedan D Legacy Sedan E Legacy Sedan F Impreza & Forester Wagon G Legacy Wagon (Outback models) K Legacy Wagon M Impreza Coupe P Outback Wagon T Baja X XT/SVX Coupe
Engine types
The engine type is specified in character six of the Subaru VIN for passenger cars.
VIN Code Description 2 1800cc FWD 3 3300cc AWD 4 2200cc AWD 6 2500cc AWD 8 3000cc FWD
Models
The model is identified in character seven of the Subaru VIN for passenger cars.
VIN Code Description 1 Base 2 Brighton 3 L 5 LS/S 6 LSi 7 GT/RS 8 Outback/Sus 9 Postal Vehicle
Restraint types
The restraint type is specified as character eight of the Subaru VIN for passenger cars.
VIN Code Description 2 Automatic Seat Belt without Air Bag 5 Manual Seat Belt w/ Driver/Passenger Air Bags 6 Manual Seat Belt w/ Driver/Passenger Air Bags and Side Air Bags C Manual Seat Belt w/ Driver/Passenger, Curtain and Side Air Bags
Plants and transmission types
The plant and transmission type is specified in character eleven of the Subaru VIN for passenger cars.
VIN Code Plant Transmission 6 SIA AWD MT5 5/R 7 SIA AWD 4EAT 8 SIA AWD 4EAT (Postal) C FHI FWD 4EAT G FHI AWD MT5 5/R H FHI AWD 4EAT
  • SIA=Subaru-Isuzu of America
  • FHI=Fuji Heavy Industries
Subaru WMIs
WMI Country Description Vehicle Types JF1 Japan Fuji Heavy Industries Passenger Vehicle 4S3 USA Subaru-Isuzu of America Passenger Vehicle 4S4
Perfect write-up and and very clear.
First 3 Digits
K Subaru J Line
A Justy
B 4-dr 81-84
C 4-dr 85-89
F HatchBack 81-89
G 3-dr Coupe 86-89
K Touring Wagon 89
M Wagon 81-84
N Wagon 85-89
R Brat 81
T Brat 82-85
U Brat 86-87
W Hardtop 81-84
1 1300
2 1600
3 1600 4wd
4 1800
8 2700
1 STD Hatchback
2 DL
6 Turbo RX
7 GL Turbo 87-89
A 4spd MT
B 5spd MT
C 3AT
D 4spd 4wd MT 81-84
D 5spd 4wd MT 85-89
F 3AT 4wd
G Full Time 4wd MT
Last Digits
500001 & after Brat
Subaru VIN code
Line types
Body styles
Engine types
Models
Restraint types
Subaru WMIs
