1-3-2-4 Posted March 19, 2011 Share Posted March 19, 2011 I can't remember for sure but does the Ej25 hold more oil in the pan over the EJ22? Link to comment Share on other sites More sharing options...
johnceggleston Posted March 19, 2011 Share Posted March 19, 2011 I can't remember for sure but does the Ej25 hold more oil in the pan over the EJ22? yes, but they are interchangeable. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 19, 2011 Author Share Posted March 19, 2011 just that the oil level would be off? unless the pan is going to rust out I don't think I need a new pan just laying around. Link to comment Share on other sites More sharing options...
davebugs Posted March 19, 2011 Share Posted March 19, 2011 IIR recall it's the design of the pan and not the dipstick. Link to comment Share on other sites More sharing options...
johnceggleston Posted March 19, 2011 Share Posted March 19, 2011 just that the oil level would be off? unless the pan is going to rust out I don't think I need a new pan just laying around. not if you fill to the full line. all the dip sticks are the same. dip stick usage: http://opposedforces.com/parts/info/11140AA046/ (click on usage) Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 19, 2011 Author Share Posted March 19, 2011 Oh I see now, thanks Link to comment Share on other sites More sharing options...
bheinen74 Posted March 19, 2011 Share Posted March 19, 2011 interior baffle plates are different too. I have seen half a dozen designs, all interchange though. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 2, 2011 Author Share Posted August 2, 2011 man I'm still nervous about putting on this oil pan from a ej22.. brand new aftermarket pan since they say the ej25 pan holds about 1/2qt more so that means I need to check it more often when it's under the full mark? speaking of that I take it the seals that come with it are for the oil pick up? Link to comment Share on other sites More sharing options...
bheinen74 Posted August 2, 2011 Share Posted August 2, 2011 personally,i wouldnt put an aftermarket pan on it it, if it is made of steel. Aftermarket metals will rust in a year and you will wish you used oem. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 3, 2011 Author Share Posted August 3, 2011 http://www.amazon.com/Spectra-Premium-SUP02A-Oil-Pan/dp/B000C7QMEE Link to comment Share on other sites More sharing options...
jarl Posted August 3, 2011 Share Posted August 3, 2011 Last night I replaced the (dented) oil pan on the EJ22 I bought to replace the EJ25 on my car, with the EJ25 oil pan. Perfect fitting, so no problems whatsoever. The main difference between the two is the shape: the EJ22's is round-ish, while the EJ25 has a flat bottom, making it squarish The depth seems to be the same. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 3, 2011 Author Share Posted August 3, 2011 thanks! Link to comment Share on other sites More sharing options...
Quidam Posted August 3, 2011 Share Posted August 3, 2011 If you put that pan on a 2.5 you'll be concerned about it and need to check the oil more often. If you have a DOHC 2.5 there is simply more oil needed in the engine, more places for it to be than in a SOHC 2.2. Your call tho. hth Doug Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 4, 2011 Author Share Posted August 4, 2011 So keep the pan above full and it should be ok Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 5, 2011 Author Share Posted August 5, 2011 is one of these for the back of the oil pump? If so what's the other two rubber o-rings for? Link to comment Share on other sites More sharing options...
jarl Posted August 6, 2011 Share Posted August 6, 2011 Having something to use as a size reference would help... But if my experience helps, the oil pump o'ring should be blue. The two smaller ones look a lot like the ones I ordered for the oil dipstick tube. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 6, 2011 Author Share Posted August 6, 2011 hmm I think you are right about the dipstick seal I hear that oring from the dealer is like $6? Link to comment Share on other sites More sharing options...
jarl Posted August 6, 2011 Share Posted August 6, 2011 (edited) I bought mine at 1stsubaruparts, and I think it was $2 or so. I was ordering many more parts, so even with the shipping price it made sense. With the markup at local dealers, prices go up too quickly for my taste... $6 for an o'ring is just ridiculous. JR EDIT: I think I know where the larger o'ring goes: it looks like the one between the block and the built-in tube in the oil pan. It's not actually an o'ring, but some sort of rubber seal. I'm not talking about the pickup tube (which is bolted to the block and uses an o'ring), but what I presume is a drain at the back of the pan. Edit 2: Forget 1stsubaruparts... you are very close to subarupartsforyou I wonder if you can order through their website and pick up the stuff in person. Edited August 6, 2011 by jarl Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 6, 2011 Author Share Posted August 6, 2011 P/.N for me is 806919050 Link to comment Share on other sites More sharing options...
jarl Posted August 6, 2011 Share Posted August 6, 2011 Yep... that's the one. It was $2.20 at 1stsubaruparts, and $3 at subarupartsforyou. But shipping on either one is more than $10, so unless you are buying something else it may not make sense. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 6, 2011 Author Share Posted August 6, 2011 Pictures 6 & 7 show me what they go to http://www.importtuner.com/tech/impp_1106_subaru_oil_system_upgrade/sti_pickup.html Link to comment Share on other sites More sharing options...
