What coil wire do you use?
Sorry - meant coil..... yeah my write up might indeed say that. I haven't updated that in years. There's a lot of little changes that should be added to that document. It's a guideline - not a rulebook. I put the ECU in the glove-box and route the wireing through the passenger side firewall plug. This makes most of the wireing perfect for mounting the coil in the stock location, etc.
IIRC some parts stores can make wires to order, they just cut what you need crimp some ends on and your on your way. I've never had to do this but I hear its fairly cheap.
Option #2 is to use an accel or MSD universal wire set and have two goods sets(they're for a V8). They have a couple in the set that are really long.
Option #3 is to move your coil closer to your dizzy, along with extending your 12V coil supply wire.
