()__1337_CRAYOLA__()> Posted March 19, 2011 Share Posted March 19, 2011 i dont know what this could be i bought a used wrx 2 weeks ago i have 650 miles of ownership and it uses 1 quart per 200-220 miles and i dont abuse it at all 2,500 - 4,500 shifts premium gas. i pulled the TMIC to see if im getting oil out the turbo but there was just a very light film in the TMIC. exhaust isnt spitting raw oil out and it runs and idles smooth with no missing im at a loss. i changed the oil when i got it for penzoil 10w30 just the basic oil could that be a issue? btw it has 111347 miles on it :-\ Link to comment Share on other sites More sharing options...
AWDfreak Posted March 19, 2011 Share Posted March 19, 2011 I don't know if you know, but it is typically much better to run a synthetic motor oil in turbocharged Subarus. Running conventional is OK, but even then, it would be much better to be on the safe side and run synthetic. I know this is just a bunch of Subaru-mumbo-jumbo, but take note of the oil change interval, it's at about 3,700 miles. http://www.drive.subaru.com/sum08/sum08_turbo.htm Link to comment Share on other sites More sharing options...
Manarius Posted March 20, 2011 Share Posted March 20, 2011 Sounds to me like you bought an abused WRX. One whose rings and turbo are probably shot from abuse/too much pressure. Link to comment Share on other sites More sharing options...
davebugs Posted March 20, 2011 Share Posted March 20, 2011 When the OP posted this I had a response about the care and abuse the first 100k but didn't post it. A WRX is NOT a car to buy used unless adult owned and then it's a crap shoot. Same as some of my generations favorite cars of the time. They just get too "beat", especially by the young folks - who are the exact folks who seek them new and used. You wanna buy a good used car, buy an "average" car. High performance cars have usually seen better days. Excellent mileage tomato can cars are often owned by cheap folks who include in their cheapness lack of maintenance. From cheapest wiper blades, to cheapest filters (if they know what a filter is) to longest oil change intervals, you get the idea. A Legacy or Impreza comes to mind actually.... Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 20, 2011 Share Posted March 20, 2011 Does it smoke a little blue when you start it? Under heavy acceleration? Off throttle? Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted March 20, 2011 Author Share Posted March 20, 2011 it blows blue in the morning for a few seconds but on the throttle, cruising and everything no smoke. Link to comment Share on other sites More sharing options...
Suba9792 Posted March 20, 2011 Share Posted March 20, 2011 well there is your oil consumption problem, your rings are most likely toast, I'd say tear it down and do a complete rebuild. Or just find another good EJ20 to drop in. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 21, 2011 Share Posted March 21, 2011 Smoke at startup is generally bad valve stem seals. Probably because the car has been beat on it's whole life and the seals have literally been cooked. Link to comment Share on other sites More sharing options...
Durania Posted March 21, 2011 Share Posted March 21, 2011 Fairtax4me said: Smoke at startup is generally bad valve stem seals. Probably because the car has been beat on it's whole life and the seals have literally been cooked. Bingo. Seems to happen when the miles > 100,000 as well. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted March 21, 2011 Author Share Posted March 21, 2011 went to 15w40 rotella t changed spark plugs which looked great no buildup clean burn. im at a loss to where the oil is going Link to comment Share on other sites More sharing options...
brumby420 Posted March 21, 2011 Share Posted March 21, 2011 perhaps it is leaking oil? Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted March 21, 2011 Author Share Posted March 21, 2011 no marking on the ground nothing the whole under side of the car is dry no oil residue Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 21, 2011 Share Posted March 21, 2011 If it isn't leaking it, it's burning it. The oil is going out the tailpipe. If you see blue smoke when you start it, it's for sure burning it. I bet if someone followed you they'd say it smells like a 2-stroke when you accelerate. The turbo can leak oil into the exhaust or the intake. A failed PCV valve or clogged hoses can force oil into the intake. A cracked piston or worn rings will let it leak into the combustion chambers. Worn valve seals will let it leak into the intake/exhaust. There's lots of ways that oil gets burned, and most are expensive to fix. Link to comment Share on other sites More sharing options...
Manarius Posted March 21, 2011 Share Posted March 21, 2011 Quote went to 15w40 rotella t changed spark plugs which looked great no buildup clean burn. im at a loss to where the oil is goingWith as much oil as you are using, as many including myself have said previously, it most certainly is either the rings or the turbo. It's going to be expensive. There's no question about it. It's not leaking, it's not the PCV. It's either the turbo or rings. Time to start saving money because it's going to be at least a grand if it's rings and close to it if it's the turbo (although, no oil in the IC makes it seem like that may not be the case). Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted March 21, 2011 Author Share Posted March 21, 2011 91Loyale said: If it isn't leaking it, it's burning it. The oil is going out the tailpipe. If you see blue smoke when you start it, it's for sure burning it. I bet if someone followed you they'd say it smells like a 2-stroke when you accelerate. The turbo can leak oil into the exhaust or the intake. A failed PCV valve or clogged hoses can force oil into the intake. A cracked piston or worn rings will let it leak into the combustion chambers. Worn valve seals will let it leak into the intake/exhaust. There's lots of ways that oil gets burned, and most are expensive to fix. i actually had a friend follow me and he saw no smoke and smelt nothing unusual from the car Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 22, 2011 Share Posted March 22, 2011 Oil's going somewhere. If it ain't leaking it's burning. A compression test will tell you if the rings are failing. A leakdown test will tell you how bad. Turbo's don't generally leak into the intake when they go bad. They puke oil straight into the exhaust system and will smoke like a steam train. Small puffs here and there when coming off throttle are your first signs. Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 22, 2011 Share Posted March 22, 2011 Quote i actually had a friend follow me and he saw no smoke and smelt nothing unusual from the car Obviously fairies are stealing your oil while you sleep then. Don't drown in de-Nile, the engine is beat. Run Rotella 5w40 and carry a spare quart all the time. Check and fill with every gas tankfull. Just got done swapping a ej257 block into an 02 wrx that had some serious oil consumption issues. The rings were so spanked that it would slowly lurch down a hill if you parked it in first with the engine hot. The E-brake doesn't work either, so you had to be careful where you left it. Still had good power right up until the #2 and #3 rod bearings spun. Everything was so worn in that engine that it couldn't keep the oil pressure up anymore. The light would flicker at idle when warm. Link to comment Share on other sites More sharing options...
