Announcements
Grandma's Subaru
I think I'm going to pull the engine and re-seal it.
I'm going to need new front fenders. What is the interchange on these? Can I get some of the newer model years if I convert the grille/headlights too?
There are some refurb fenders for an '83-'84 on eBay for $150. I assume there were cosmetic changes between the years.
the following will fit* for fenders:
80-84 wagon, sedan, 2 dr coupe
80-89 hatchback
82-87 Brat
*80-82 had antenna on drivers side. 83-84 had antenna on passenger side.
*If putting a 80-81 fender on a quad headlight setup, there is a little trimming, but it's all behind the bezel, but you shouldn't have to worry about that.
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
Awesome, that's just what I needed to know.
I'm going to check with the local Subaru shop and wrecking yards to see if they have any fenders and a hood, but if I have to I'll get some off the internet. I could use a new drivers door if I could get a decent deal. That has some rust holes, but it's probably the easiest to repair.
Salvage yard is supposedly bringing in a GL, should be able to get at least the wiring from it. Hopefully some other bits too. I want another set of wheels for snow tires (as I already have a set from my old I-Mark, but on 4x100 wheels).
Found and fixed one oil leak; the oil drain plug didn't have a gasket. It does now. Still a non-trivial leak somewhere on the backside of the engine.
Edited by Red0ktober
  • 2 weeks later...
I stopped by the salvage yard again. No GLs of my era, but two Loyales. One with the injection and 5sp DR I'd need to convert my EA81, the other with an EA82T but an auto.
So, what to do? Retrofit the EA81 with injection, or swap in the EA82T. The 5-speed swap and rear disc conversion are happening regardless.
Any other bits I should make a point to pull of either of them?
  • 2 weeks later...
What's the fun in keeping it stock? I have no other reason to have the car other than to screw around with it. I have an Isuzu that is a better 4x4, and a BMW that is more comfortable and gets better gas mileage (and goes way way faster too).
  • 4 weeks later...
I'm giving the car away this evening. Boo hoo. (not really)
I took it to the local Subaru specialist (that I've heard nothing but good about), and he gave me his opinion. It was not good.
I still have the '83 Turbo that I'm going to try to fix, but sorry grandma, I'm not going to mess with the '81.
