mookiex4 Posted March 23, 2011 Share Posted March 23, 2011 Hello all, I am not sure how to check for the problem to determine what I have to do. While driving, the steering wheel jerks to the left sharply and there is a grinding and clicking noise. It has been getting progressively worse and I was wondering how to check it out and find out what it is. At first I was thinking it may be the brake caliper, then was thinking wheel bearing or CV Joint, but do not want to take the brakes apart if I need to be looking someplace else. Thanks for any help or suggestions. Mark Link to comment Share on other sites More sharing options...
mickytrus Posted March 23, 2011 Share Posted March 23, 2011 Sounds like a bad axle cv joint...... do some figure 8's in a parking lot at like 5mph... Should hear bad clicking if it is a cv joint...... steering might get jerky as well. Link to comment Share on other sites More sharing options...
ShawnW Posted March 23, 2011 Share Posted March 23, 2011 You are going to have some indicators if its bad enough. Brake pads that are worn on a side more than the other, torn boot on the axle, resistance while spinning the wheel with it off the ground, etc. Your diagnostic skills in person, even if you are pretty novice, are going to be better than us trying to guess here on a forum. Link to comment Share on other sites More sharing options...
