1987 Brat Steering Jerks Left Sharply and Grinding/Clicking Noise
Hello all,
I am not sure how to check for the problem to determine what I have to do. While driving, the steering wheel jerks to the left sharply and there is a grinding and clicking noise. It has been getting progressively worse and I was wondering how to check it out and find out what it is.
At first I was thinking it may be the brake caliper, then was thinking wheel bearing or CV Joint, but do not want to take the brakes apart if I need to be looking someplace else.
Thanks for any help or suggestions.
Mark
You are going to have some indicators if its bad enough. Brake pads that are worn on a side more than the other, torn boot on the axle, resistance while spinning the wheel with it off the ground, etc.
Your diagnostic skills in person, even if you are pretty novice, are going to be better than us trying to guess here on a forum.
