Wiper arm won't attach to ANY standard blades!
I have a '91 XT-6, and as you probably know, it's like owning a special needs child. Every time something has to be fixed, I expect to catch hell with finding its non-standard parts. This time it's the wiper blade. I took the blade off because I wanted to place the entire wiper and not just put in a refill. However, the arm apparently doesn't fit any standard connector that comes with any wiper blades I've tried.
Can I replace the arm with one that has a more universal connector? Or am I stuck using the stock blade and just putting refills in it? If so I better find a new one, cuz I trashed that POS.
It seems to be too wide to fit any of the connectors. Maybe machine that mofo down to where it will fit...
