Abramjames Posted March 24, 2011 Share Posted March 24, 2011 I am having a hard time figuring out how to use the self diagnosis. All of the cables seem the same. I really would like to figure it out. Link to comment Share on other sites More sharing options...
Deener Posted March 24, 2011 Share Posted March 24, 2011 Welcome to the board. First off, what you mean by 'self diagnosis' is unclear. Check underneath your steering wheel for a couple of screws holding the plastic kick panel on. With that kick panel removed and the engine on, you can move the wires aside and you should see a flashing red light. Long flashes are tens and short flashes are ones. Write down the sequence and analyze it to the point where you can see the pattern repeat. Once you have retrieved the 'code'(s) you can seach here in this forum again for what that particular code means. Here is a link to an explanation of the codes: http://www.ultimatesubaru.org/forum/showthread.php?t=49918 Link to comment Share on other sites More sharing options...
Abramjames Posted March 30, 2011 Author Share Posted March 30, 2011 I will try doing what you are saying. Thank you. Link to comment Share on other sites More sharing options...
naru Posted March 30, 2011 Share Posted March 30, 2011 I am having a hard time figuring out how to use the self diagnosis. All of the cables seem the same. I really would like to figure it out. Pages 22,31 in the ea-82 manual here: http://www.finleyweb.net/JonsStuff/SubaruDocumentation.aspx Link to comment Share on other sites More sharing options...
GirlWithALegacy Posted April 10, 2011 Share Posted April 10, 2011 Search button is your friend Thats how I found this thread! Thanks guys! Link to comment Share on other sites More sharing options...
