93 loyale engine light on
I am having a hard time figuring out how to use the self diagnosis. All of the cables seem the same. I really would like to figure it out.
Welcome to the board.
First off, what you mean by 'self diagnosis' is unclear. Check underneath your steering wheel for a couple of screws holding the plastic kick panel on. With that kick panel removed and the engine on, you can move the wires aside and you should see a flashing red light. Long flashes are tens and short flashes are ones. Write down the sequence and analyze it to the point where you can see the pattern repeat. Once you have retrieved the 'code'(s) you can seach here in this forum again for what that particular code means. Here is a link to an explanation of the codes:
http://www.ultimatesubaru.org/forum/showthread.php?t=49918
  • 2 weeks later...
