There is a relay in the fuse box under the hood for the high beams. It is the same relay as the low beam, so you can switch them to confirm if that is the problem. More than likely though, you just have two bad bulbs.
fixed. thank you again. the relay must have not been making a good connection. i swapped them. the two closest to the shock tower and i had both bright and dim. i then switched them back to where they were and i still have bright and dim. so once again thank you.
  • 3 weeks later...
My '90 has/had this issue. I'd have to push/pull/push the stalk to get the Hi-beams to work.
Do you get Hi-beams if you pull the switch toward you for the 'flash-to-pass' feature? If so, then it's likely in the stalk like mine.
Mine seems to be working again, for now, but I don't drive much where I need them, so it's not something I'm going to worry about fixing.
TD
When i had a bad alternator that was causing randome surges i blew two set of brand new bulbs and it was only the high beams. If one of the wires in the bulbs are broken then i would check all of ur connections to make sure they are getting proper load to them and if they are fine maybe try testing the relays to make sure they arent going out. Also have u tried pulling the lever toward u just to see if they work, if it works then u know its the lever
