Gloyale Posted April 20, 2011 Share Posted April 20, 2011 monstaru said: You need a HighGuys lift. Or any lift. Just a lift. Bad. Those tires are gonna be stuffed against the fenders the first time you go wheeling. Link to comment Share on other sites More sharing options...
monstaru Posted April 21, 2011 Author Share Posted April 21, 2011 (edited) wow, i was pissed at that last night......... just the trailing arm wil help a bunch.and i have been wheeling for years man.not just in subaru's.i know the ins and outs.this isn't my first rodeo. i have yet to cut the pipe for the fronts, already have the back fingered out. its all about time... cheers, b Edited April 21, 2011 by monstaru Link to comment Share on other sites More sharing options...
subaruguru Posted April 21, 2011 Share Posted April 21, 2011 Brian its looking sweet! I am going to start working with bill on getting My legacy lifted we will need to go wheeling sometime two new gens tearing up the trails:grin: Cheers R. Link to comment Share on other sites More sharing options...
987687 Posted April 21, 2011 Share Posted April 21, 2011 That thing is a beast!!!!! Love it! :banana: Link to comment Share on other sites More sharing options...
el_freddo Posted April 22, 2011 Share Posted April 22, 2011 monstaru said: now, do i go with the $.11's and have to stay viscuous.or go 3.9's and maintain diff lock. That is a tough question! I personally would stick with the diff lock, but the advantage of the 4.11 diff ratio is very appealing too. With this in mind, some fellas over here have been "building" the best of both worlds. With some ingenuity and good welding skills they've created a 4.11 ratio pinion shaft that will fit the RX AWD tranny with locking centre diff. Here are some pics of the one that is destined for my AWD L box build: ^ Note the weld about a 2 inches from the pinion gear. I'm not sure if this was made from two EJ AWD pinion shafts, one being the 4.11 gear or if an RX AWD pinion shaft was cut and shut. I currently don't have an EJ pinion shaft handy to compare I'm sorry. Food for thought, sorry I didn't actually give you an answer to your question! monstaru said: wow, i was pissed at that last night... Yeah you were!! Classic. 987687 said: That thing is a beast!!!!! Love it! :banana: Totally agree! The thing looks wild with no lift and the large tyres! Keep up the good work - can't wait for some pics on the tracks! Cheers Bennie Link to comment Share on other sites More sharing options...
Mugs Posted April 22, 2011 Share Posted April 22, 2011 (edited) UMMM He did lift it. Brian is a masterful builder, and a great problem solver. He did not just put some big tires on it and call it a day. He really did lift it what your seeing is the tires filling in the wheel well after the lift. Because believe those wouldn't have even fit in a stock height imp wagon. Now go take you wanna be criticism somewhere else. What you got that's lifted huh? And if you did I bet it was with store bought pre fabbed bolt in stuff, not your own engineered items. Edited April 22, 2011 by Mugs Link to comment Share on other sites More sharing options...
monstaru Posted April 22, 2011 Author Share Posted April 22, 2011 Mugs said: UMMM He did lift it. Brian is a masterful builder, and a great problem solver. He did not just put some big tires on it and call it a day. He really did lift it what your seeing is the tires filling in the wheel well after the lift. Because believe those wouldn't have even fit in a stock height imp wagon. Now go take you wanna be criticism somewhere else. What you got that's lifted huh? And if you did I bet it was with store bought pre fabbed bolt in stuff, not your own engineered items. slow down speed racer, there is an arguement to whether or not this is a LIFT.....i could care less. he has some good things to say as well. cheers, b Link to comment Share on other sites More sharing options...
monstaru Posted April 22, 2011 Author Share Posted April 22, 2011 el_freddo said: That is a tough question! I personally would stick with the diff lock, but the advantage of the 4.11 diff ratio is very appealing too. With this in mind, some fellas over here have been "building" the best of both worlds. With some ingenuity and good welding skills they've created a 4.11 ratio pinion shaft that will fit the RX AWD tranny with locking centre diff. Here are some pics of the one that is destined for my AWD L box build: ^ Note the weld about a 2 inches from the pinion gear. I'm not sure if this was made from two EJ AWD pinion shafts, one being the 4.11 gear or if an RX AWD pinion shaft was cut and shut. I currently don't have an EJ pinion shaft handy to compare I'm sorry. Food for thought, sorry I didn't actually give you an answer to your question! Yeah you were!! Classic. Totally agree! The thing looks wild with no lift and the large tyres! Keep up the good work - can't wait for some pics on the tracks! Cheers Bennie bennie, i simply do not have the means to weld the shafts.otherwise i would go that route. the diff lock would be sweet, but i have never had it before , so i don't know what i am missing:lol: if i WAS gonna weld some pinions i would just go for the $.$$'s.. anyways,it was more of a rhetorical question by the time i had even gotten done typing it.i have wanted better final drive ratio for an offroad application for a while...so 4.11's it is.... unless , some 4.44's just dropped in my lap out of thin air....then i would SERIOUSLY consider it. thanks for the pics.just out of curiousity do you have the specs of the welding equipment and process they went through to do the pinions? cheers, b Link to comment Share on other sites More sharing options...
987687 Posted April 22, 2011 Share Posted April 22, 2011 Hmm, after I do the 5speed swap into my legacy I'll have a 4.44 rear and front out of the auto... Link to comment Share on other sites More sharing options...
monstaru Posted April 25, 2011 Author Share Posted April 25, 2011 (edited) so, every damn thing that could be bent on the rear end was.therefore no adjustment was gonna take care of it. so i rednecked some stuff had to cut some stuff. ..that super long god damn bolt sucks...... bent ************........... take all of it out.replace with MOAR.... how she was last night after the hellday that is rust.......************ rust. complete adjustability......priceless... the bed camber/toe issues, are obviously taken care of.bent something or other.whatever the hell it really was is beyond me.so i fixed the problem. a cheers, b mad thanks to Mugs, and Bacc for the help and photos.... Edited April 25, 2011 by monstaru Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted April 25, 2011 Share Posted April 25, 2011 Ah, I see the long bolt has a new enemy. It really is a b**** to get out when it's rusted in good, isn't it? Glad to see you got your toe problems fixed with an upgrade Always nice to see that. I'd say something token like "keep up the good work" or something cookie cutter like that, but I know you'll do whatever the hell you want. So just do whatever the hell you want! :-p Twitch Link to comment Share on other sites More sharing options...
baccaruda Posted April 25, 2011 Share Posted April 25, 2011 (edited) Pics of the maiden voyage with rear discs and wheel spacers Edited April 25, 2011 by baccaruda Link to comment Share on other sites More sharing options...
Pooparu Posted April 25, 2011 Share Posted April 25, 2011 That's so cool. Link to comment Share on other sites More sharing options...
GirlWithALegacy Posted April 25, 2011 Share Posted April 25, 2011 Someone's been playing with photoshop! sweet editing. Link to comment Share on other sites More sharing options...
Mugs Posted April 25, 2011 Share Posted April 25, 2011 Dude, You have no idea how bad I want to do this now. That thing is so sick...It looks like a real live stomper, all beefy and squaty, sorta bull doggish too. I thought a wagon looked good lifted, but this takes the cake, with the Imp body lines and all. Now start tubing the bumpers man...well get the motor in a reliable condition first. Link to comment Share on other sites More sharing options...
baccaruda Posted April 25, 2011 Share Posted April 25, 2011 you have no idea thanks. GirlWithALegacy said: Someone's been playing with photoshop! sweet editing. Link to comment Share on other sites More sharing options...
monstaru Posted April 26, 2011 Author Share Posted April 26, 2011 welp, i new i had more to do to the rear fenders to get them where i want them.so, i jumped some railroad tracks today to find THE spot that was rubbing. i found it:grin:.. i say jumped, it was more like dropping in a big pothole, hitting the track, bouncing off of it and coming down hard, sideways-ish. it is obviously something you slow down for usually.. but other than the tire chunking, yes i chunked it.straight cosmetic .doonk, doonk, doonk,doonk, all the way home:lol: i was glad to find out it was rubber. i think i may actually put swaybars back on.then make disconnects.i gotta measure the swaybars i pulled off.and make a mounting surface on the links. but , all in all i would say succeessful. the struts have settled out about now.so i think i can actually get this thing into shape to go fast, AND deep. cheers, b Link to comment Share on other sites More sharing options...
newsoobdude Posted April 27, 2011 Share Posted April 27, 2011 Man that looks absolutely SIC monstaru!! How much ground clearance do you have under your oil pan and rear diff? Also, how close are the tires to the struts? Link to comment Share on other sites More sharing options...
GirlWithALegacy Posted April 27, 2011 Share Posted April 27, 2011 (edited) So my dad comes home from work yesterday (He drives bus for STA) and says to me, "I saw the coolest looking little Subaru today! It was like an Impreza but not. Something '...sport'. Blue, lifted with big awesome wheels, missing something on the front but I don't remember what... Man, it was cool!" I showed him this thread and he was like THAT'S THE ONE! Makes me proud to know ya on here! Thought you'd enjoy hearing that Edited April 27, 2011 by GirlWithALegacy Link to comment Share on other sites More sharing options...
monstaru Posted April 27, 2011 Author Share Posted April 27, 2011 yeah, i almost goit hit by a bus yesterday.i was wondering.... kidding, this thing gets some looks for sure. cheers, b Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted April 27, 2011 Share Posted April 27, 2011 I dig the hacked bumper. Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted April 27, 2011 Share Posted April 27, 2011 thatswhatshesaid said: I dig the hacked bumper. I think I see a pushbar/custom bash guard in this car's future... Twitch Link to comment Share on other sites More sharing options...
michael appel Posted April 28, 2011 Share Posted April 28, 2011 (edited) Dig the imp totally baccaruda said: Pics of the maiden voyage with rear discs and wheel spacers Edited April 28, 2011 by Subarutex Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted April 28, 2011 Share Posted April 28, 2011 Twitch de la Brat said: I think I see a pushbar/custom bash guard in this car's future... Twitch that's what I'm waiting to see.... Link to comment Share on other sites More sharing options...
Subarutex Posted April 28, 2011 Share Posted April 28, 2011 FILTHY. Don't trade this one. This should be your facebook pic Link to comment Share on other sites More sharing options...
