chopsubie Posted March 30, 2011 Share Posted March 30, 2011 Any of you t-case guys find a source for straight driveline tubing? The OEM driveline on my 81-83 ea81 wagons is flared. I need to shorten the driveline and the only options I have is to buy new weld on yolks that use the more common Inch size tubing. (2.5" x .062 wall) If I could find some metric tubing for less than $100 bucks I could re-use the OEM weld yolks. Are you T-case guys using the sammy and Toyota drivelines with conversion U-joints? Thanks Quote Link to comment Share on other sites More sharing options...
monstaru Posted March 31, 2011 Share Posted March 31, 2011 your local driveline shop should be able to source it. if not, i used the stock suzuki driveline, and u joint to match to a subie u joint.it is 1 thousandth off according to measurement.it fits. and spins fine. cheers b Quote Link to comment Share on other sites More sharing options...
Uberoo Posted April 6, 2011 Share Posted April 6, 2011 what about cutting up some stock subaru driveshafts from the junkyard?that or some old nissan driveshafts. Quote Link to comment Share on other sites More sharing options...
