subcyclist Posted March 31, 2011 Share Posted March 31, 2011 Silly question, how long should a clutch last on a outback? Reason I'm asking is thinking of buying a 96 with only 80,000 miles and they are saying they just replaced the clutch and am wondering if the mileage is BS... Thanks, Jeff Link to comment Share on other sites More sharing options...
davebugs Posted March 31, 2011 Share Posted March 31, 2011 The cars I see typically are far beyond that before needing replaced. However if the baffle plate was leaking. Of if they didn't know how to drive a stick. I'd suppose a lot of city driving or towing. Other things come to mind. But that isn't many miles for any clutch it would seem if they knew how to drive. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 31, 2011 Share Posted March 31, 2011 (edited) It entirely depends on where the mileage was done and what kind of driver was doing it. I just replaced a clutch on a 2003 S10 with 85k on it. The friction surface was getting thin but not gone - it had been a paper delivery vehicle and owned by a kid - the pressure plate was overheated and lost it's spring tension. And I have done Subaru clutches (first one) that lasted 255k miles. When you are on the freeway the miles rack up with no use of the clutch. Mileage is a bad indicator of clutch life. It's basically meaningless. The quality of the replacement is a big issue as well - who did the job and what parts were used. Was the flywheel resurfaced... etc. I've had to swap out clutches that were poorly done with cheap parts after only a 10k or so. GD Edited March 31, 2011 by GeneralDisorder Link to comment Share on other sites More sharing options...
MilesFox Posted March 31, 2011 Share Posted March 31, 2011 my 78 toyota camper with 300,000 miles has its original clutch. Driving habit, and probper adjustment plays a lot in clutch life. most failed clutches i see are caused by over-tightened clutch cable. a clutch, with good maintenance and proper driving, should last at least 200,000 miles or more Link to comment Share on other sites More sharing options...
subcyclist Posted March 31, 2011 Author Share Posted March 31, 2011 Thanks guys, I'll report back if I buy it. Cheers, Jeff Link to comment Share on other sites More sharing options...
subsince77 Posted April 1, 2011 Share Posted April 1, 2011 The clutch in my 97 OBW went at 175,000. The new one had 65,000 on it when I sold the car. With proper care they go a long long ways, but someone could have fried it, oiled it, or replaced when it didn't need to. Link to comment Share on other sites More sharing options...
nipper Posted April 1, 2011 Share Posted April 1, 2011 I have seen clutches go anywhere between 10,000 miles and 160,000 miles. It just depends upon the drivers skills and bad/good habits. A worn clutch is never something that should be held against a car. Link to comment Share on other sites More sharing options...
