Robbman Posted April 1, 2011 Share Posted April 1, 2011 I was pulling out of a parking lot and all of a sudden the engine stopped, no sputtering out or any other sounds, it just went dead, and it still has battery power. Ive gotten suggestions that it may be a bad coil, are there any other possibilities? Link to comment Share on other sites More sharing options...
naru Posted April 1, 2011 Share Posted April 1, 2011 Broken timing belt,bad fuel pump....... Link to comment Share on other sites More sharing options...
MilesFox Posted April 1, 2011 Share Posted April 1, 2011 broken timing belt. timing belt drives the distributor, which drives the coil and the fuel pump. non-interference, easy fix. Search the terms milesfox and timing belt. good info Link to comment Share on other sites More sharing options...
mickytrus Posted April 1, 2011 Share Posted April 1, 2011 Yeah timing belt.... pull distributor cap... see if rotor turns...... there are 2 belts so pull the cover on the passengerside belt.. where the cam gear is. Link to comment Share on other sites More sharing options...
Robbman Posted April 1, 2011 Author Share Posted April 1, 2011 (edited) Thanks for all the help, it's still stuck where it stopped and I'm on my way to pick it up right now (probably tow it), but I also wanted to add that the dash lights still come on when the ignition is on, but not the dash clock, cigarette lighter, and radio, all the components that draw constant power from the battery, and I just sprayed some starter fluid into two of the cylinders and got no response from the engine. Edited April 2, 2011 by Robbman More info Link to comment Share on other sites More sharing options...
DrKrazy Posted April 2, 2011 Share Posted April 2, 2011 (edited) but I also wanted to add that the dash lights still come on when the ignition is on, but not the dash clock, cigarette lighter, and radio. Does this help? Hmm was reading the thread and agreeing with everyone but, with that info it sounds like it's possibly one of your fusible links (inside the black box right by your battery). Does the car still crank over? And does it sound normal while cranking or a bit fast? Got a multimeter? Check for power on both sides of each of the fusible links and check to see if the distributor and rotor are turning as mentioned above. Edited April 2, 2011 by DrKrazy Link to comment Share on other sites More sharing options...
