92_rugby_subie Posted April 3, 2011 Share Posted April 3, 2011 When Im in gear going down the road with light acceleration (cant hear it over exhaust under heavy acceleration) or even just keeping speed, I hear a loud whine from the engine that goes away when I push my clutch in... Does this mean I need a new clutch? Vehicle is a 1986 Subaru GL Sedan, 5 Speed D/R 171.3k miles. Quote Link to comment Share on other sites More sharing options...
nickolai Posted April 3, 2011 Share Posted April 3, 2011 I've had a bad clutch in a Loyale, and it didn't make any noise. When I gave it gas to go up a hill, the rpms would increase, but the speed of the car would lag behind. Have you tried revving the engine while the car is sitting to see if it's caused by engine speed? Check your power steering fluid. Mine whines when it gets low. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted April 3, 2011 Share Posted April 3, 2011 I had a noise in my 91 legacy that sounded like George Jetsons car when the car was cold and I was accelerating. Went away when I pushed the clutch. Never fully figured out what it was but I was told it was a bearing on the pilot shaft of the tranny. Not saying yours is this, but its something that has been said to me before. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 4, 2011 Share Posted April 4, 2011 Much more likely an input shaft bearing in the tranny. Noise with the clutch pedal depressed is throw-out bearing. Noise when clutch is released is inside the transmission. GD Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted April 4, 2011 Author Share Posted April 4, 2011 I will say that (in a separate note) that when I am turning, I hear the whine from my power steering pump when Im going slow and cranking it. I dont really know where to go from here, I was kindof hoping that when I pull the engine (to fix an oil issue) that I could just do a new clutch and be saved, but if its tranny :/ I suppose I could wait, I do plan way off in the financial future to do an EJ22 swap and an AWD swap with an ej22 tranny... for now, and then when Im rich n famous, 6 speed sti swap lol @GD, so does this mean tranny needs to be replaced/rebuilt? I read that you said its better to get another tranny since they are so common, but I thought the D/R wasnt that easy to find. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted April 4, 2011 Share Posted April 4, 2011 5 speed D/R's are a dime a dozen... I sold the one from my GL for $50 I had been told with my legacy that the input bearing squeaking was not a big deal as long as the tranny had gear oil in it. (hopefully GD confirms that) Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 5, 2011 Share Posted April 5, 2011 The D/R's are easy find. I wouldn't worry about it till you can hear it over the stereo. The input shaft bearing arrangement on the D/R is quite robust and it is unlikely to fail suddenly. GD Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted April 5, 2011 Author Share Posted April 5, 2011 I think over the stereo is catastrophic failure lol Hopefully its no big deal for now. Quote Link to comment Share on other sites More sharing options...
