s'ko Posted April 4, 2011 Share Posted April 4, 2011 (edited) I did a bone head move the other day. I was driving and the gas was really low. I forgot to get more gas before it ran out and I ran it dry. I put more fuel in and tried to start it but I can't seem to get it to start. AAA came and the car turned over with starter fluid but did not stay on. Pulled the fuel input lines and there fuel pressure is very low. AAA towed me home. I called Andrew (hondasucks) and he suggested that I cycle the ignition a few times to put fuel into the engine. Still no start. I got a new fuel pump, strainer and filter and replaced the parts. I took an air hose and blew the lines clear. It is still not getting fuel. I connect the green test plugs and the fuel pump cycles on and off. I pulled the gas input line to the filter and saw the gas flow. reconnected the input line and then disconnect the line from the fuel filter to the fuel rail. Gas is flowing there. disconnected the output line from the fuel rail and gas is not coming out. The pressure from the fuel pump seems to be kinda low. What am I missing? Thanks BW. Edited April 6, 2011 by s'ko Quote Link to comment Share on other sites More sharing options...
Cougar Posted April 4, 2011 Share Posted April 4, 2011 You could try starting the engine using starter fluid and keep it running with short bursts for about 15 seconds. Hopefully the engine will be able to run on its own by then. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 4, 2011 Share Posted April 4, 2011 i've ran mine out of fuel multiple times and it's never caused problems. dump in a gallon (or less) of gas and it firse right up. 4 or 6 cylinder, auto or manual? check engine light? not sure what is causing it but running out may not be your issue? maybe it was coincidence that it quit running while it was really low on gas? Quote Link to comment Share on other sites More sharing options...
s'ko Posted April 4, 2011 Author Share Posted April 4, 2011 no CEL. 4 cylinder automatic. Car ran great before this happened. I had the fuel injectors cleaned out about 2 months ago. What keeps the fuel rail from getting gas? Fuel pressure regulator? Probably call AAA and get it towed to a shop for them to work on. I really really need the car working on Tuesday. BW Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 4, 2011 Share Posted April 4, 2011 (edited) nothing out of the output line? interesting. here's a picture of the FPR in a 2000 - should be the same as yours. i'd suspect maybe it's hosed? pull the vacuum line to it and if there's gas in there then it's ruptured. not sure if the newer ones work that way and can fail that way, but it's a test that works on some. if you see gas then it's hosed. if you don't see gas - then it might still be hosed or not. if the return line has any rubber hose portion i have heard you can squeeze the line (use some vice grips maybe) and that may get it to start. though i've never tried it. starting fluid might be the simpler test. a squirt around some vacuum lines should only take a few seconds. *** EDIT *** Forgot to attach pic Edited April 4, 2011 by grossgary Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 4, 2011 Share Posted April 4, 2011 The in tank fuel pump motor is cooled by the gasoline that surrounds it. It is possible that running out of gas over heated the pump motor damaging it. Another thought is that completely draining the fuel tank pumped some residual crud/dirt from inside the tank. These particles got trapped in the fuel filter to the point of clogging the filter. Maybe a new filter will fix the problem. Quote Link to comment Share on other sites More sharing options...
s'ko Posted April 6, 2011 Author Share Posted April 6, 2011 Problem resolved. Fuel pump went out. Airtex fuel pump that I bought from Oreilly was defective. $300 later, mechanic had it working. BW Quote Link to comment Share on other sites More sharing options...
Olnick Posted April 6, 2011 Share Posted April 6, 2011 Glad you're back on the road. Sorry about the $300 hit--but at least it wasn't worse. Quote Link to comment Share on other sites More sharing options...
TahoeOutback Posted April 7, 2011 Share Posted April 7, 2011 Wow that sucks when a new part is bad. Sure makes you doubt yourself. Good job on the repair. Did you actually run out of gas or did the pump die. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 7, 2011 Share Posted April 7, 2011 a new fuel pump failed? wonder if new pumps are low grade compared to subaru originals? subaru pumps don't fail very often, i might be tempted to replaced with a used one if i ever have one fail. Quote Link to comment Share on other sites More sharing options...
mikec03 Posted April 7, 2011 Share Posted April 7, 2011 My fuel pump died. But I went to a junk yard and pulled a used one for an old subaru. I guess that was smarter then I knew. Quote Link to comment Share on other sites More sharing options...
