1-3-2-4 Posted April 7, 2011 Author Share Posted April 7, 2011 Well I was going to ask because I'm searching here and i don't (so far) see any thread where someone replaced any of the shift forks.. the good thing is at least online at subaru parts it's $44 But how are they on the shift linkage? Are they held in by a pin or something like that? but until I open up the trans it's unknown to all of us what happened Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 7, 2011 Share Posted April 7, 2011 Replacing the shift forks is possible if one is broken..... but you have to open the trans to do it so it's not really worth discussing till you open it and find out that's the actual problem. The forks are held to rods with set-screws. GD Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 7, 2011 Author Share Posted April 7, 2011 Replacing the shift forks is possible if one is broken..... but you have to open the trans to do it so it's not really worth discussing till you open it and find out that's the actual problem. The forks are held to rods with set-screws. GD I'm just as eager to open it up as anyone else but just set screws? Is that where they bend at? I remember when it last snowed I tried to pull a subie out of a snow bank in reverse and I noticed when I was unable to.. (I needed studs) When it was time to go back into 1st my car got stuck in rev for a few and i remember for a few days I had a hard time getting in and out of 4th gear but it was mostly when pulling out but it smoothed out Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 7, 2011 Share Posted April 7, 2011 I would imagine they bend or break at the ends where they engage the shift collars. I doubt you could break one where they are attached to the rod. That portion is a lot thicker. GD Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 7, 2011 Author Share Posted April 7, 2011 Well I will update when I pull the transmission I will pick up the jack hopefully same day i don't know how quick I will get to the transmission, I just don't know if the jacks I have now are high enough I get about 17" of lift from them. Link to comment Share on other sites More sharing options...
Ricearu Posted April 8, 2011 Share Posted April 8, 2011 Im with the party on this one. just stab another in. And GD, I would listen to an RA gearset whine too! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 8, 2011 Author Share Posted April 8, 2011 I'm sure it's going to need another transmission but what fun is it to just take it out and not open it Speaking of that what can you get for the transmission in scrap? Link to comment Share on other sites More sharing options...
johnceggleston Posted April 8, 2011 Share Posted April 8, 2011 Speaking of that what can you get for the transmission in scrap? it varies by area and quality of the metal. in my town scrap cars are now bringing $9.50 per hundred pounds. (in NC it's 8.50.) so a legacy might bring $300. a trans maybe $25. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 9, 2011 Author Share Posted April 9, 2011 (edited) ah I understand.. question, the pair of jackstands I have now the max list is 16 3/8" is that high enough to take the tranny out while it's turned sideways? I've never tried to lift at the max height because for one I never needed to go that high. And I'm going to guess it's going to be better off if I can raise the car level? I'm sure that high of an angle is going to be a pain. finally I can have reason enough to get another jackstand and another is to check the replacement transmission while it's in the air. Anyone have a part number to that bushing linkage that held in by the spring pin that connects to the shift rod? if I'm going to drop the tranny then I want a nice feeling shift I'd hate to go to the dealer and just print out a picture and point to it and they are clueless *edit is the part # 35047AC030? I thought it was only a $24 part.. Edited April 9, 2011 by 1-3-2-4 Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 10, 2011 Author Share Posted April 10, 2011 anyone know what size the driveshaft bolts are? I need to get some hand tools since mine are all SAE sized. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 10, 2011 Share Posted April 10, 2011 The bolts that hold the carrier to the body, probably 12 or 14mm, I don't remember exactly. You will have to remove the skid plate on the diff carrier to allow the driveshaft to fall down. Then take the carrier bearing bolts out, the driveshaft will bend in the middle and the end will side out of the trans. Just buy a metric mechanics set from sears or something. If you don't have a 1/2" breaker bar get one of those too. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 10, 2011 Author Share Posted April 10, 2011 The bolts that hold the carrier to the body, probably 12 or 14mm, I don't remember exactly. You will have to remove the skid plate on the diff carrier to allow the driveshaft to fall down. Then take the carrier bearing bolts out, the driveshaft will bend in the middle and the end will side out of the trans. Just buy a metric mechanics set from sears or something. If you don't have a 1/2" breaker bar get one of those too. I have a 1/2" breaker bar so I should be ok since i'm going to be doing all of this I should replace the rear separator plate? Did they still use plastic back in 97? I still got the plate and the screws in the closet. I'm going to guess my jack at it's max height is tall enough to slip the tranny out sideways Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 10, 2011 Share Posted April 10, 2011 Probably plastic. Metal or plastic, at the very least reseal it while you have access. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 10, 2011 Author Share Posted April 10, 2011 Yeah for sure.. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 11, 2011 Author Share Posted April 11, 2011 can I use RTV to seal the tranny back up? Link to comment Share on other sites More sharing options...
Gloyale Posted April 11, 2011 Share Posted April 11, 2011 can I use RTV to seal the tranny back up? "the Right Stuff" is far better. RTV will work, but will leak in a year or two. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 11, 2011 Author Share Posted April 11, 2011 "the Right Stuff" is far better. RTV will work, but will leak in a year or two. What is the right stuff? three bond I've never seen locally.. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 11, 2011 Share Posted April 11, 2011 It's called "The Right Stuff". I don't recall who makes it but I've seen it at just about every auto parts store. I used anaerobic on mine, and It has held up very well so far. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 11, 2011 Author Share Posted April 11, 2011 ah Permatex 29208 it's cheaper online then the store besides it's going to rain tomorrow and the weekend so very little work is going to get done.. plus I gotta pick up some taller jackstands one with at least a 22" max lift oh btw the rear oil separator is plastic Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 13, 2011 Author Share Posted April 13, 2011 (edited) *UPDATE* I went to see the car (paid for) No HG leak.. only thing is the tranny was like bone dry so I went out and put in 2 qt of diff fluid.. Anyways while I did not drive the car more then 2 Ft forward and backwards I had no problems with 1st, 2nd or getting into reverse.. HOWEVER in neutral or any gear the tranny makes this sound I'm so sorry I did not do a video on my phone I forgot all about it.. the closest sound I can describe it as being a rotating sound from what sounds like from inside the tranny.. I'm not sure if it would be the TOB I felt the tranny case and I did not feel that much vibration so it could be the TOB? Anyways 2 Qt got me up to the middle of the diff dipstick. Edited April 14, 2011 by 1-3-2-4 Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 13, 2011 Author Share Posted April 13, 2011 car sounded like this just sitting idle from the tranny area. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 14, 2011 Share Posted April 14, 2011 Bad input shaft bearing. Possibly other damage if its been run low on fluid. That bearing is easy to change once you split the tranny. About $65 at the dealer. No telling what else is damaged though. Could be a basket case - you won't know till you open it. For sealing the tranny I use permatex anearobic or loctite 518. I use copious amounts of the stuff as it has become my go-to sealant for everything. I occasionally will use some ultra grey but not on transmissions. The transmission case is a perfect example of what anearobic was made for. GD Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 14, 2011 Author Share Posted April 14, 2011 When I was under the car I was wondering why the women was turning away.. I found out it was because her uncle died because this car slipped off the jack. Having said that and her uncle worked on the car and its a new clutch and all I think I'm just going to buy a new clutch again... I did buy ultra gray but I'm going to use it for something else. I'd have to look at that thread again but the bearing is the one after the rubber seal right? Because I don't think a little rubber ring would be $65 Also how much permatex anearobic do I need? is (I think it's) the 5 oz is that enough? Link to comment Share on other sites More sharing options...
puhi Posted April 14, 2011 Share Posted April 14, 2011 I had a chinese clutch disk spit out a spring and cause some similar sounds and symptoms. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 14, 2011 Author Share Posted April 14, 2011 not sure what it is but i doubt its a exedy Link to comment Share on other sites More sharing options...
